4.7 Clackity-clack noise on acceleration - JeepForum.com
post #1 of 5 Old 10-20-2015, 11:19 AM Thread Starter
distantdog
Over the past few months, I've noticed that, usually at hiway speeds, when I accelerate, I can hear a "clackity-clackity" noise coming from the engine. Sorry, thats the best way I can describe it.
I THINK its the engine, but its hard to be sure. Seems central behind the dash.
I mostly notice it under load (going uphill) at higher speeds.
FWIW - Early this year I had a head gasket replacement job done by a shop. Heads were resurfaced as well.
2004 WJ Laredo Special Edition V8 4x4
SOLD: 2001 TJ Sport
distantdog is offline
post #2 of 5 Old 10-20-2015, 11:25 AM
WJCO
The conditions under which it happens based on your description, leads me to believe it is pinging. But, I wouldn't describe that as 'clickity-clack.' If it is pinging, try some higher octane gas to see if it goes away or run a decarb through the intake. BG 44k is a good chemical to run in your tank from time to time.
If pinging isn't your issue, post a video of the noise you're hearing if you are able to.
Zone 4,33s,ProRock44,roofrack,Zeon 8s,grill guard,washer relocated,DIY tire carrier,sliders.
WJCO is offline
post #3 of 5 Old 10-20-2015, 12:25 PM
Double E
Double E's Avatar
Also sounds somewhat like the driver's side exhaust manifold bolts snapped.
Get under the hood when cold, engine running. Tug on the throttle cable under the airbox to rev the engine a little and if you hear it from the driver's side, by the heat shield, Bob's your uncle.
Common issue and plenty of threads on the topic.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is online now
post #4 of 5 Old 10-28-2015, 08:05 AM Thread Starter
distantdog
Ran a tank full of high octane and a bottle of fuel system cleaner and the noise is gone.
Haven't looked at the manifold, but since the noise is gone, I am hoping its ok.
SOLD: 2001 TJ Sport
post #5 of 5 Old 10-28-2015, 09:06 AM
WJCO
Sweet. Glad to hear. Hope it stays that way.
WJCO is offline
