4.0L Water Pump Replacement - JeepForum.com
post #1 of 19 Old 06-20-2012, 07:51 AM Thread Starter
drgonzo92
2003 WJ
Does anybody have a write up or pictures of how to replace the waterpump on an 03 WJ 4.0L? Whats everybody using for replacement brand?
drgonzo92 is offline
post #2 of 19 Old 06-20-2012, 08:05 AM
ChrisHager
Administrator
ChrisHager's Avatar
I used MasterPro Select from O'reilly Auto.
It's quite a simple procedure. Basically, you take off the belt, unbolt the 4 bolts holding the pulley on, pop the pulley off, remove the hoses that are clamped onto the water pump, then remove the bolts holding the water pump on. Clean it up and slap the new one on (with a gasket of course). When you clean it, be sure both surfaces are free of any old gasket. Also, you may want to stuff a shop towel or two into the hole in the head to avoid getting old gasket material in there while you clean it. On reassembly, I think I went above and beyond and also used a little RTV along with the new gasket to ensure I would have no leaks. You will need to transfer the old pulley and the metal tube from the old pump to the new pump as well.
At this point, I would consider a new thermostat and flushing the cooling system and refilling with a 50/50 mixture of Zerex G-05/Water.
Here's a picture of the water pump. The thermostat is right above the water pump.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #3 of 19 Old 06-20-2012, 08:56 AM
dzachareas
Make sure you put the 90 degree tube on the new water pump BEFORE you install it onto the engine. It won't go on after you've installed the water pump, there isn't any room to twist it on, the valve cover is in the way. I learned this the hard way.
dzachareas is offline
post #4 of 19 Old 06-20-2012, 08:59 AM
ChrisHager
Administrator
ChrisHager's Avatar
Ah very good point!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #5 of 19 Old 06-20-2012, 11:50 AM
1AAdam
great advice thanks a lot!! i have to track down a coolant leak this weekend.
Adam
1aauto.com
888-844-3393
1AAdam is offline
post #6 of 19 Old 06-20-2012, 12:21 PM
specia1k
I've used GMB water pump's from Advance Auto Parts on both WJ's and been happy so far. Plus if you order online using Promotion: CCABIN
$10 off orders of $30 or more - $20 off orders of $50 or more - $40 off orders of $100 or more!! Just order online, get the discount and designate to pick up the parts at your neighborhood store. So your ~$57 WP is ~$37.
Good luck...
2004 Jeep Grand Cherokee Limited 2x4 4.0L
2002 Jeep Grand Cherokee Sport 2x4 4.0L
1998 Jeep Grand Cherokee Laredo 2x4 4.0L
"Three daughters, three Jeeps"
specia1k is offline
post #7 of 19 Old 06-20-2012, 12:25 PM
Luzoshi
2003 WJ
this help me out too!. Thanks ChrisHager!
Luzoshi is offline
post #8 of 19 Old 06-20-2012, 01:39 PM
Sukey77
Be sure not to overtighten the thermostat housing/ or water pump bolts. I felt like a complete tool when i did that.
Sukey77 is offline
post #9 of 19 Old 06-20-2012, 05:29 PM
rostig1
It sounds simple on paper or computer screen. Mine was fun. It took about 3 or so hours. Then again I have the tow package so I have two fans plus trans cooler.
Just from my experience go a head and replace the radiator and hoses. I skimped on the radiator and was pulling it about two weeks later.
If its worth doing once its worth doing right!!!
rostig1 is offline
post #10 of 19 Old 06-20-2012, 07:00 PM
kc2mrg
its easier than you think, i did mine with the fan out (was also replacing it) so it made it easier, and i also used the GMB new (not reman) water pump from advance, only advice ill give you is DO NOT just use the gasket, put some rtv (they will give you the right stuff) on the pump where the gasket goes, then put the gasket on then put more sealant on top of the gasket, and like everyone else said, put the metal pipe on before you install the new pump (personally i just got a new pipe from the dealer, was about $20) and the bolt torque is 22 ft lbs on the bolts for the pump, id suggest while your in there getting a new t-stat, its an easy 2 bolts, and only use mopar coolant, should be there 5year/100k coolant
2004 Grand Cherokee Laredo 4.0
Rusty's 2.5" coil/shock lift
265/70/16 General Grabber AT2's
Superchips 3875 Flashpaq
Flowmaster exhaust
West Virginia Jeep Club member
JEEPINWV.COM
kc2mrg is offline
post #11 of 19 Old 06-20-2012, 07:13 PM
ChrisHager
Administrator
ChrisHager's Avatar
Originally Posted by kc2mrg
...and only use mopar coolant, should be there 5year/100k coolant
Zerex G-05 fits Mopar's standards...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #12 of 19 Old 06-20-2012, 07:24 PM
kc2mrg
hmm... didnt know that, thanks for the info, it was just easier for me to buzz down to the jeep dealer down the road and get there stuff, just what ever you do, do not mix different color coolants!
Flowmaster exhaust
JEEPINWV.COM
kc2mrg is offline
post #13 of 19 Old 06-20-2012, 09:52 PM
ChrisHager
Administrator
ChrisHager's Avatar
Believe it or not I've *heard* color doesn't necessarily designate what blend you have. But yes, a good rule of thumb is: Never mix colors. Safest bet.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #14 of 19 Old 01-26-2013, 04:59 PM
happygil0303
What metal pipe are you guys talking about to Install before installing the pump
happygil0303 is offline
post #15 of 19 Old 01-26-2013, 06:02 PM
Cirruslydakota
The heater core feed tube on the left side, see the picture above. Also, I started buying water pumps labeled as "New" not reman after a batch of bad water pumps from autozone years ago on my chevy 350.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
Water Pump Replacement wany23 WJ Grand Cherokee Forum 14 03-26-2013 10:29 AM
2000 4.7 water pump replacement tip keith20mm WJ Grand Cherokee Forum 0 12-04-2011 09:09 PM
Water Pump Replacement and Refill Question leadsled jeep WJ Grand Cherokee Forum 0 05-23-2011 09:00 PM
wj water pump replacement now wont stay on mtnmarc WJ Grand Cherokee Forum 0 01-07-2011 01:10 AM
Help! In the middle of a water pump replacement. 01grander WJ Grand Cherokee Forum 11 04-11-2010 09:31 PM
