4.0l performance ideas - Page 2 - JeepForum.com
post #16 of 27 Old 12-19-2011, 06:32 PM
Ravie
[QUOTE
But I would stick to around 4.10 gears 4.56s could be harsh on the highways with stock tires.
99' Grand Cherokee Laredo 4.7 quadra dr[/QUOTE]
Hey, hopefully you check this again... I was thinking about doing 4.10's but my WJ will be a DD...how is it on the highway? If I could find some of those...3.76 gears, that might be nice. I won't probably do much crawling...maybe on occasion but not all the time...
Also...I would imagine that if a guy gears the back...he's gotta gear the front, too...that would get expensive quick!
sorry for the highjack...
1999 WJ - Over 10k on the 4.0 rebuild. FB/BDS 2" lift (2.5") w/Bilstein 5125's. General Class Ham...KC0LUA
Burlbook48 sez "Nothing moves a project along faster than cubic dollars." Certified Thread Killer.
Ravie is offline
post #17 of 27 Old 12-19-2011, 06:40 PM
gphunkplp
that is correct u would have to do both do have a towing packaage on your jeep if so you may already have the 3.73 gears if not there 3.55s
Sent from my optimus
gphunkplp is offline
post #18 of 27 Old 12-19-2011, 06:50 PM
Ravie
Nope. just stock 3.55 D30's. Does anyone sell those 3.73's? All I can find are 4.10's
Ravie is offline
post #19 of 27 Old 12-19-2011, 06:54 PM
gphunkplp
theres some in the classifeds i just checked, i may have 99 limited for a part out soon ill post it up if it happens
post #20 of 27 Old 12-19-2011, 07:04 PM
Jeepgcl9947
My friends wj has a 4.0 with 3.73s and it feels more peppy than my 4.7 with 3.73s just his jeep is not friendly on highways
Jeepgcl9947 is offline
post #21 of 27 Old 12-20-2011, 07:08 AM
nickblack
Have your engine stroked to a 4.6 L, the 4.0 is an easy engine to work on. Save your money on all the other things people have suggested here because none will produce results anywhere close to what stroking it will do. Can up your horsepower to over 300 with stroking. Save up and do it right.
nickblack is offline
post #22 of 27 Old 12-20-2011, 09:25 AM Thread Starter
rfritz7
How much would it be to stroke it and where would I get that done I know nothing about this stuff. It sucks
rfritz7 is offline
post #23 of 27 Old 12-20-2011, 12:34 PM
nickblack
look for a local shop who does engine work. You can buy a stroke kit for your engine. Do a google search or ask on this forum. Any engine rebuild shop can do it for you. Not sure what the cost is, I would guess about $1200-1500 complete. If you start doing all these other things that were suggested, the cost of those will add up and all of them together won't get you remotely close to 300 hp that a stroking will get. Trust me, you will be very happy.
post #24 of 27 Old 12-20-2011, 02:27 PM
jfazio5188
Tadaaaaaa
jfazio5188 is offline
post #25 of 27 Old 12-20-2011, 03:51 PM
Blktjsport
I have the following on my wj and tj 4.0's:
K&N costume true cold air intake with prefilter
62mm bored throttle body
Bosch 4 hole injectors
2.5" flowmaster 40 catback
The difference with all these combined is great and definatly noticeable.
Next will be ceramic coat the intake and exhaust manifolds from heat
All in preparation for stroker motors but the damn engines won't die
2001 WJ -WIFES K&N FIPK~2.5" FLOWMASTER 40~2.5" BB~ BILSTEINS~ 255/70/18 BRIDGSTONE A/T JK'S
1999 TJ SPORT- NP242~SYE~K&N APOLLO COWL CAI~2.5" FM40 ~3.5" RE~ BILSTEIN 5100~D44~33" BFG MT~ DAVES RACK~ BUSHWACKERS~ HELLA ECODE DDM 6K HID
Blktjsport is offline
post #26 of 27 Old 12-20-2011, 08:20 PM
TurboTPI
I turboed my 95 4.0l ZJ. I know its not a WJ, but im sure it would be about the sam eto do. Mine with 33in tires and 3.55 gears, gets better gas mileage than when it was stock. 23mpg highway and it will run with my wifes 02 WJ with a 4.7HO in a race.
02 WJ Limited 4.7l HO-stock (Hers)
95 ZJ 4.0 Turbo-up 5.5 on 33x12.5's, Ford 8.8 w/Artec truss (His)
92 Firebird Formula custom turbo setup (His)
09 Polaris Dragon 800 (His)
TurboTPI is offline
post #27 of 27 Old 12-20-2011, 09:56 PM
liquidxit2
Stroke, port and polished head, cam, long tubes, matching exhaust, ported throttle body, fuel system, ignition system, intake system done right (k and n fipk alone isnt enough) and a tune should have you at a pretty nice power level. As for gears id honestly do 3.73 at that power level for fuel mileage.
2002 Jeep Grand Cherokee Limited 4.7 low output quadradrive. 31in General Grabber AT2, OME HD, bilstein 5100, IRO sway links, addco rear sway. Kolak 3in exhaust with flowmaster SUV 50, magnaflow 3in cat, Custom K and N FIPK, modded airbox with ram air, Fastman 71mm Throttle body, PML RFE Deep pan, Autometer digital trans temp gauge, P.I.E. aux adapter, Infinity reference 3.5/6x9/6.5, 200w inverter, surco rack, front/rear/cargo husky liners.
liquidxit2 is offline
