4.0L fan shroud removal.. - JeepForum.com
post #1 of 17 Old 06-15-2012, 02:52 PM Thread Starter
4x4Jeep
in the middle of replacing my radiator...i don't understand how the fan shroud is supposed to come out. i took the 2 bolts out, the the shroud itself is surrounding the fan blades and there's no room to remove it.
Build -
SOLD
4x4Jeep is offline
post #2 of 17 Old 06-15-2012, 03:18 PM
boomersoonerGC
It's attached with 4 bolts. The bottom bolts are miserable.
http://www.jeepslimited.com/index.php?option=com_content&task=view&id=36&Itemi d=126
Some people have cut off a cheapo box wrench to fit the space, some just pull the whole radiator up some. Both are effective solutions.
boomersoonerGC is offline
post #3 of 17 Old 06-15-2012, 07:59 PM
Jeepoman
Hi 4x4, Since you are replacing the rad. half the battle is over, the easiest way by far is using three tools, a1/4 ratchet and deep 10mm socket a thin long 10mm combo wrench and a 10mm flat ratchet combo that has a swivel end on the ratchet side this last one will give you the necessary angle for the lower drivers side bolt.. Once you have disconnected the the rad hoses and drained the fluid you'll have plenty of room, best to start with the bottom bolts, the passenger bolt takes the most time to do, easiest from the top with the 10mm combo wrench, disconnect the wiring plug from the fan and pull the fan connector from the shroud, its held by a plastic tit with barbs, be gentle you may need it if the new fan doesn't come with it, this will give you more room to turn the wrench......Now slip the box end on the bolt and turn to loosen, you"ll only get a bit better than 1/8 of a turn, be patient, once you move the bolt out a couple of threads you"ll be able to turn it with your finger tips and off quickly, the driver's side use the the swivel fat ratchet, from underneath slip the the ratcheting box end on the bolt using your pointer finger, the swivel will give you the correct angle to the shroud, just hold it in place and ratchet away, you'll have it off in a jiffy, the top bolts well you know what to do, once all bolts are out just carefully pull the assembly up and a little to your left and it comes right out. Replace in reverse order. Good Luck.
Jeepoman is offline
post #4 of 17 Old 06-15-2012, 08:37 PM
IslandHopper
Haven't done the Jeep.... But a Ford Ranger... Had to take the fan/clutch loose from the crank to get the shroud up and out of the truck.
It was a bit of a pain getting to the fan bolts with the shroud in place, but overall it came out pretty easy doing it that way.
IslandHopper is offline
post #5 of 17 Old 06-15-2012, 08:59 PM
little_Jeep
Do you have both a mechanical as well as an electic radiator fan? If so, you will have to remove the fan and fan clutch from the water pump via the 36mm nut. The fan, and shroud will all some out as a unit. Are you having issues with the passengerside lower shroud bolt as well?
little_Jeep is offline
post #6 of 17 Old 06-15-2012, 09:43 PM
narnwv
narnwv's Avatar
Since he said "I got the two bolts out" I'm assuming he's not aware there's two lower bolts he needs to get at as well.
OP: Since you're pulling the radiator, leave the shroud attached and pull it all out as one piece. It's 100 times easier
~Aaron
narnwv is offline
post #7 of 17 Old 06-15-2012, 10:57 PM Thread Starter
4x4Jeep
apparently whoever worked on my jeep before didn't bother to put the 2 lower bolts back in, so i only had to take out 2 (upper) bolts.
i ended up having a buddy come over to give me a hand and we finished it up friday night, without taking the shroud out.
thanks for the replies.
Build -
SOLD
4x4Jeep is offline
post #8 of 17 Old 06-16-2012, 06:13 AM
little_Jeep
Removing the radiator, the mechanical fan (towing package) and electric fan, all as one unit with fan shroud still attached would have required some additional hands, which I didn't have. Ended up, I couldn't do this anyway as
one of the "neat" things I discovered with mine is the lower radiator hose was impossible to get to with the shoud in place as the hose clamps were attached while the shroud was out. I have the skids included in the Up Country package so the front lower radiator skid limits things. While I had mine apart, I replaced the lower radiator hose, making sure I could get to clamps without having to remove the shroud.
post #9 of 17 Old 06-16-2012, 07:42 AM
Cirruslydakota
Whoever decided to put that lower bolt beside the steering box should be tied up and burned at the stake. I had an awful time getting that out when I replaced my electric fan, but it is possible if you sacrifice a 10mm wrench.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #10 of 17 Old 06-16-2012, 08:10 AM
little_Jeep
I don't remember the driver's side as being a problem as much as the passengerside.... the pass side was pressed against the frame rail so tight a wrench wouldn't go over the head of the bolt. I was able to go thru the top of the grill and remove the passenger side bold and really losen the driver's side, then I could raise (lift up) the passengerside of the radiator enough to clear the frame rail... It seems whomever designed the 4.0L WJ's liked to build those puzzles, like the twised nails.
post #11 of 17 Old 06-17-2012, 12:54 AM
kc2mrg
when i pulled mine, i found the driver side harder than the pass side lower, pass side lower comes right out with a swivel extension the driver side however was like a 30 minute process, i left it out, it has a new home in my toolbox now
2004 Grand Cherokee Laredo 4.0
Rusty's 2.5" coil/shock lift
265/70/16 General Grabber AT2's
Superchips 3875 Flashpaq
Flowmaster exhaust
West Virginia Jeep Club member
JEEPINWV.COM
kc2mrg is offline
post #12 of 17 Old 09-19-2013, 09:09 PM
hotrod760
Talking
It took me way to long to remove the bottom driver side bolt on the fan shroud, so I found a tool that makes this process so much easier to remove. Check it out.
Husky SAE Flex Ratcheting Wrench Set (5-Piece). there are other similar brands. The flex ratcheting wrench was a God send for this situation.
hotrod760 is offline
post #13 of 17 Old 09-19-2013, 09:56 PM
new2site
I've heard about "that bolt" BEFORE reading this thread... like you suggested, I saw some guy on Youtube who heated and bent a cheapy 10 mm wrench...that's what I'll be doing when I do my E-fan next week.
Like "kc2" mentioned ...it's going to go in my spare bolts pile AND STAY THERE once I remove it.
new2site is offline
post #14 of 17 Old 09-19-2013, 10:23 PM
Knightrider9827
^ haha! I never put that bottom bolt back in either
Knightrider9827 is offline
post #15 of 17 Old 09-20-2013, 12:37 AM
losttech
losttech's Avatar
I cut my shroud out with a dremel then removed the dreaded driver side lower bolt.
Its out and will never ever go back in that was the most frustrating experience I have had on my jeep.
3 bolts keep it in just fine though.
I bought some hose clamps with wingnuts on them so I can do them by hand since that bottom one is such a pain in the butt to get to.
losttech is offline
'01 WJ electric fan/shroud removal laybackman WJ Grand Cherokee Forum 14 01-12-2013 08:52 PM
Fan shroud label Gran_Paradiso WJ Grand Cherokee Forum 3 03-02-2012 05:17 PM
Fan shroud removal 4.0 MoparMan1990 WJ Grand Cherokee Forum 10 01-20-2012 09:14 PM
Dropped a socket in my fan shroud... what should I do about it? Sublme437 WJ Grand Cherokee Forum 6 12-26-2011 06:28 PM
Help fan shroud removel help SwaYY WJ Grand Cherokee Forum 4 05-28-2010 12:05 PM
