4.0 Valve Cover Gasket - JeepForum.com
post #1 of 20 Old 01-15-2014, 02:44 PM Thread Starter
bayouguy
Wj 4.0 Valve Cover Gasket
This may seem like a simple / dumb question but I have all of the stuff to change my valve cover gasket but am wondering if the rear CCV elbow needs to be removed from the cover to have enough room to clear the fire wall?
On the 93 I did it had to be removed but those were much easier being 1/4 turn removal.
I have new elbows / grommets to go in.
Anything else I should be looking for while the cover is off?
bayouguy is offline
post #2 of 20 Old 01-15-2014, 03:06 PM
rcwj04
When I did my valve cover I had to take it off, it's going to be a major pain to remove it without breaking it. Can't put the new one back on until the valve cover is back on and that one is a pain to. Have fun!
You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
Just a 19 year old kid with a Jeep, and broke because of it, and loving every moment.
2004 WJ Laredo 4.0 116k
2" BDS coils & Bilstein 5100's | Addco rear swaybar with energy bushings |
K&N FIPK | glasspack | plasti-dipped badges | 17" moabs | HID's, 245/65/17 Cooper Discover AT3 | Rola rack | Fawkes stand alone shackle tabs | Bed lined interior (what a pain that was)
rcwj04 is offline
post #3 of 20 Old 01-15-2014, 03:19 PM
doityourselfMM
doityourselfMM's Avatar
As I recall, as the valve cover is lifted up, it can roll over, as it clears the rockers. If not, saw off the top, but leave a little to grab on to, for removal. It will most likely crack and shatter anyway. They become brittle as hell.
The front edge/ lip of my VC was hitting the upper radiator hose clamp. When I moved the clamp to gain access, of course coolant started to flow.
Keep track of which bolt and/or stud comes out of which hole.
Lube the new donuts and elbows with engine oil. I did the grommet in the VC first, installed the VC, then wiggled the elbows in place. I'm sure you know, but the elbow with the valve goes in the rear of the VC.
doityourselfMM is offline
post #4 of 20 Old 01-15-2014, 03:56 PM
spud2388
I changed mine a few weeks ago, and I would recommend replacing both the front and rear elbows and grommets at the same time. They are inexpensive and easier to do once its off the motor. And you DO NOT have to wait and install the rear one until after the cover is on, but it does make it a little easier. A little hint, put a little oil around the new grommets and they slide right on.
spud2388 is offline
post #5 of 20 Old 01-15-2014, 04:02 PM
rcwj04
I must be losing my mind but I remember my valve cover didn't have the clearance under the top of the firewall that it needed to fit, no matter how I angled it, it would not fit
rcwj04 is offline
post #6 of 20 Old 01-15-2014, 04:11 PM
new2site
YOU CAN REMOVE IT WITH THE CCV ELBOW ON....YOU DO THIS BY LIFTING THE FRONT UP...THEN TURN COVER TOWARDS PASSENGER SIDE AS YOU LIFT UP AND PULL OUT...it's tight but will come out this way.
And I recommend doing it this way...otherwise if you try to take it off on engine (elbow) you're probably going to break it and pieces will fall down onto your cyl head ...and you never know..one could fall down into the pushrod valleys and then you'd be hating life.
*Plus it's easier to remove and install elbows with it off the engine..still a headache though..they're really pressured into the fitting holes good. I strategically used a small 1x1 wood beam and rubber mallot to tap edges of new elbows in place.
new2site is offline
post #7 of 20 Old 01-15-2014, 04:58 PM Thread Starter
bayouguy
I have both new elbows and grommets.
Anything else in particular I need to look for / check while I have the cover off?
bayouguy is offline
post #8 of 20 Old 01-15-2014, 05:31 PM
ShadowTek
Check the wire bundle that runs behind the valve cover for melting.
Even if you don't have damage, I'd put a peice of hose over the last head bolt on the drivers side to keep it from rubbing into the wire bundle later.
Some aluminum heat shield tape over that area would be good too. The hole on the left in my pic was due to pure heat from contact with the valve cover. The hole on the right was due to contact with the bolt.
ShadowTek is offline
post #9 of 20 Old 01-15-2014, 05:56 PM
new2site
*Be careful with unhooking the throttle /kickdown/cruise control cables...the ends/connectors are plastic and can break easily if you're removing them incorrectly:
-The one closest to the throttle body prys off (flat head screwdriver) sideways TOWARDS the throttle body / rear of vehicle.
-The next two "unhook" by slightly pulling them towards the Driver-side fender / turn throttle to gain a little slack.
new2site is offline
post #10 of 20 Old 01-15-2014, 06:06 PM
ShadowTek
Originally Posted by new2site View Post
*Be careful with unhooking the throttle /kickdown/cruise control cables...they are plastic and can break easily if you're removing them incorrectly
When I put mine back together, I lubed them with silicone grease so they'll hopefully come off next time with minimal force.
post #11 of 20 Old 01-15-2014, 06:10 PM Thread Starter
bayouguy
Good info
I suppose if I am getting this far I may as well clean the throttle body too.
bayouguy is offline
post #12 of 20 Old 01-15-2014, 08:51 PM
spud2388
Clean around the valve cover BEFORE you take it off. There is a lot of junk and debris that builds up between the cover and manifolds and a quick dusting/air blowing/wiping will remove the loose stuff and keep it from getting into the crankcase. And, of course, take your time and learn something.
spud2388 is offline
post #13 of 20 Old 01-15-2014, 11:50 PM
RigoJeep
Spray some WD40 on the hose connected to rear CCV valve and you should be able to twist it off. I replaced the breather hose from the air intake to the front CCV valve with 1/2" ID radiator hose ($2). Dealer wanted $28! Save yourself some time, just break that rear valve...it's gonna come out in pieces anyway!
RigoJeep is offline
post #14 of 20 Old 01-16-2014, 04:52 PM Thread Starter
bayouguy
All good info.
Thanks
bayouguy is offline
post #15 of 20 Old 01-29-2014, 07:51 PM
detroitrust
Spud is so right. If you've had a leak, which is the reason to change the valve cover gasket, it will be caked with debris as was mine. It's a royal ***** to clean after you expose the area under the cover and you haven't cleaned it. Also, I don't know what you guys use to clean the cover, but mine is a sob to clean. The oil is baked on and tough to get off. Maybe its the freaking cold in my un-heated garage. Tried brake cleaner, GUNK, acetone, and now soaking with degreaser. Really wish I had a parts cleaner.
Now, removing mine, I broke the plastic housing that holds the wire harness as I tried to wiggle it off the bosses so I could get some additional clearance. I don't think I need to replace it. All the stuff near the exhaust manifold is brittle. My rear retainer for the wire harness attached to the rear boss on the VC was broke but again , I don't think its an issue.
I did clean the throttle body and it was a freaking mess. Don't know if this will benefit anything, but the dealer wanted $60 to do it along with $230 to do the VCG. I can't believe they would take the time and caution to clean the area trying to avoid debris falling into the head.
SO far I have the VC off and awaiting parts to reassemble. This is not something I would like to do often. You guys that get this done in an hour are wizards.
detroitrust is offline
