4.0 tick/knock - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > 4.0 tick/knock
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 04-10-2014, 09:39 AM   #1
Acc0919mc
4.0 tick/knock
Hey guys, i changed my oil a few days ago with rotella t5 10w30
I have a really loud tick/knock (i really dont know the difference) and i cant figure out what is wrong. sounds like its either #3 piston, or a rocker on cylinder 3.
Heres a video: https://www.youtube.com/watch?v=C9tf...ature=youtu.be
Its a lot louder in real life
Just ignore my stupid minecraft videos.. lol
Acc0919mc is offline   Reply With Quote
Unread 04-10-2014, 09:47 AM   #2
Super6XJ
does it go away after a few min or so?
Your Welcome
Super6XJ is offline   Reply With Quote
Unread 04-10-2014, 09:51 AM   #3
Acc0919mc
No, its really bad when i first start it, but then it quiets down, but never goes away. it also ticks/knocks faster when i rev it
That was fully warmed up by the way
Unread 04-10-2014, 10:16 AM   #4
brouwmat
brouwmat's Avatar
Piston skirt possibly. I think i hear the telltale low end clunk there.
What year and how many miles?
Sent from AutoGuide.com App
brouwmat is offline   Reply With Quote
Unread 04-10-2014, 10:53 AM   #5
Mrhaney
Piston skirt
Mrhaney is offline   Reply With Quote
Unread 04-10-2014, 06:56 PM   #6
Acc0919mc
2000, 145008k
Unread 04-10-2014, 07:11 PM   #7
Acc0919mc
Btw, that deep tap tap tap tap tap, is the EVAP silonid or whatever in the top right of under the hood
The EVAP starts at 0:05
Unread 04-11-2014, 06:25 AM   #8
brouwmat
brouwmat's Avatar
Piston Skirt. Get a stethoscope and put it high on the side of the oil pan. I am willing to bet it gets louder.
Good luck. Pretty common with these 4.0's. I did mine at 120k, sounded just like it and it wasn't the evap solenoid. Rebuild or Reman is your best bet. Used motors are almost as much as a reman (unless you can find a smoking hot deal somewhere)
Unread 04-11-2014, 06:51 AM   #9
Acc0919mc
I hope thats really not what it is... my dad says we are junking it if that's whats wrong (its in his name)
The only thing is it never made a sound until i changed the oil, it made no noise at all with crappy Valvoline in it
Unread 04-11-2014, 07:07 AM   #10
dlundblad
2003 WJ
Could also be a cracked head? Take the oil cap off and shine a flashlight down there. Does it say Tuppy?
David_Silver WJ Laredo 4.0
2"BB with Monroe Reflex shocks on 245/75/16 Goodyear Duratracs
OME SS_IPF series 868 lights
Plus a few other junkyard goodies...
dlundblad is offline   Reply With Quote
Unread 04-11-2014, 07:58 AM   #11
Acc0919mc
I dont think that what it is, but i guess it doesnt hurt to check. Nope, it doesnt say anything
Unread 04-11-2014, 08:00 AM   #12
Acc0919mc
I will do a cold start video today sometime, but its raining atm and im not going outside
Unread 04-11-2014, 08:35 AM   #13
Ravie
That doesn't seem loud enough to me to be the typical piston skirt problem. There are only 900 other vids of that in YT...lol I thought mine was still up but I guess I deleted it. Mine was MUCH louder.
The thing with 4.0's is...the oil pumps in all of the 99-04's sucked. So depending on how worn they are and other factors...it could just be lifters... hard to say.
1999 WJ - Over 10k on the 4.0 rebuild. FB/BDS 2" lift (2.5") w/Bilstein 5125's. General Class Ham...KC0LUA
Burlbook48 sez "Nothing moves a project along faster than cubic dollars." Certified Thread Killer.
Ravie is offline   Reply With Quote
Unread 04-11-2014, 08:49 AM   #14
bugaboots
If it were me I would pull the valve cover and check the rockers. If you find nothing then I would drop the pan and check it for piston skirt.
I will say that when I switched my cherokee to the t5 that it got louder than with Mobil 1.
1995 Cherokee 4.0 Stock(for now)
2002 Grand Cherokee Sport, OME HD lift, Bilstien 5100's, 63mm Bored t-body, IRO 2.5 exaust, 245/75/16 Revo2, Front tow hooks, 4.6L long rod stroker, Factory Jeep brush gaurd
bugaboots is offline   Reply With Quote
Unread 04-11-2014, 08:59 AM   #15
bushido7seven
I say don't worry about it. Unless your burning , leaking oil , overheating or poor performance . If your going to junk it and it still works just drive into the ground. My jeep 4.0 has the same noise and it get 21 mpg and drives well. The noise hasn't gotten louder. Also next time you change your oil use Quaker state defy or rotella they have a lot of zinc which helps protect the engine.
Good luck
bushido7seven is offline   Reply With Quote
