4.0 knocking tapping? - JeepForum.com
post #1 of 11 Old 09-12-2017, 04:57 PM Thread Starter
maxxedout
Got a 99 4.0, it started with a tapping sound which I thought was the lifters , so installed new ones. Then thought it was a rod ,replaced rod bearings and checked piston skirts still same sound. Checked fly wheel bolts and still the same sound, could it be cam bearings??? Have access to rebuilt engine for 800 dollars should I just ditch it and get the engine and cut my losses....
maxxedout is offline
post #2 of 11 Old 09-12-2017, 11:10 PM
Squarecat
1993 XJ Cherokee
How bad/loud is it?
Though it is well-known that it's just something a 4.0 might do and I wouldn't suggest blatantly ignoring a potential problem however, from the repairs you've already done (which address the most common sources of that noise), I'm wondering how much more you should worry about it.
Seems like a bigger loss to ditch an otherwise good engine you've improved key areas of over a noise they are known to make.
Sent from my iPhone using Tapatalk
Squarecat is offline
post #3 of 11 Old 09-13-2017, 03:33 PM Thread Starter
maxxedout
This is not a normal knock, hits hard. Can hear it coming up the drive way from the house and its about 50 yards long...It had the normal jeep sounds before but this just started and has gotten real bad and loud, still runs great just running me nuts....
post #4 of 11 Old 09-13-2017, 06:32 PM
MOTOWN
I bet your exhaust manifold is cracked and leaking.
MOTOWN is online now
post #5 of 11 Old 09-14-2017, 07:07 AM
seabee26
It may sound funny, but pull codes. Mine ONLY knocks (sounds EXACTLY like a rod) when it's throwing a P0301 thru P0306 and missing like crazy... no codes, no miss, no knock.
Just something else to look at.
seabee26 is offline
post #6 of 11 Old 09-14-2017, 05:35 PM Thread Starter
maxxedout
Also changed intake exhaust gasket and checked for cracks, found nothing .
It has no miss and runs and idles fine no codes active or pending??
RUNNING ME NUTS......
post #7 of 11 Old 09-14-2017, 10:48 PM
rep-tile
Cash 4 Clunkers Survivor
rep-tile's Avatar
^ I'd like to know what that is.
Maybe you can try narrowing down where exactly it is coming from with a stethoscope.
04 WJ 4.0 - Avital 4103, DB-ALL
91 XJ 4.0 - Avital 4103, Stage-2 aFe intake system, BBK high flow Throttle Body, Jones Exhaust A3518M-5
rep-tile is offline
post #8 of 11 Old 09-15-2017, 02:03 PM
new2site
This is probably going to sound stupid, but since most other possibilities have been brought up / exhausted..... and although loud, maybe not as loud as your noises.....but if, for whatever reason, a spark plug indexing washer failed, or was not tightened just quite enough, you WILL get a loud continuous tapping noise (mimicking bad lifter sound etc) from compression sneeking by washer failure .....but engine will not miss being spark plug is in enough still. Ask me how I know..
new2site is offline
post #9 of 11 Old 09-24-2017, 06:53 PM Thread Starter
maxxedout
Worth a check, been thru everything else. Be sorta funny if thats all it is. Will check this week ...Thanks
post #10 of 11 Old 09-24-2017, 07:09 PM
Spotthejeep
I've read somewhere that it could be a bad injector. My 4.0 has a tick but goes away if turn engine off then restart. Suspecting #3
Spotthejeep is offline
post #11 of 11 Old 09-24-2017, 10:44 PM
Vvrjrlaw
I had a 4.0 that had a banging sound that appeared to be coming from deep within the engine. Oil pressure was low. You don't say how many miles are on it but I would check the crank bearings. Mine was a crank bearing but from loss of pressure it scored the rod bearings so I replaced the rods and crank bearings after I had the crank cut. Good luck.
Vvrjrlaw is offline
