4.0 fuel injector upgrade 4.0 - JeepForum.com
post #1 of 10 Old 03-04-2013, 05:09 PM Thread Starter
ZB_WJ
Jeep is running sluggish, Mpgs 14.3 highway. I'm thinking fuel filter or pump/screen. But with under 100k does this sound right? Jeep lacks power on hills and almost seems like Rear break dragging, there is a clink coming from around that area, but nothing has locked up or smoking. Main problem is on hills, this thing is a dog. On BB with 245/75r16s and wouldn't think they would hurt me that bad.
Ive searched to find the thread that says what injectors to use to upgrade and was asking for your input? I've heard neon injectors are the way to go but don't know what year/model I can use.
Are there better injectors to use? Or w
Should I start worth fuel filter?
Any help is merited with a digital pat on the back
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #2 of 10 Old 03-04-2013, 05:16 PM
Umbrella
2006 XK Commander
Saw this post: LINK
Used injectors from a Taurus.
2006 XK 4.7 Limited
1995 XJ 4.0 Sport
Umbrella is offline
post #3 of 10 Old 03-04-2013, 05:36 PM Thread Starter
ZB_WJ
Yup saw that one and will probably go that route, But was wondering about any better ones?
ZB_WJ is offline
post #4 of 10 Old 03-04-2013, 06:50 PM
shockracer
If you could find an early 95 neon, they had a 5 hole injectors.
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #5 of 10 Old 03-04-2013, 07:00 PM
wvracer821
wvracer821's Avatar
i used ones from a mustang. i did a write up on it. it was okay for a replacement but nothing fantastically better than stock.
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #6 of 10 Old 03-05-2013, 01:03 PM Thread Starter
ZB_WJ
Ok, thanks for the input guys. If my fuel filter doesn't fix my sluggishness then I'm def going to upgrade injectors. I wouldn't think they'd be bad, only about 92k miles on it
ZB_WJ is offline
post #7 of 10 Old 03-05-2013, 07:53 PM
cjcyr8
If you have a 4.0 I-6, carefully check the fuel injector wiring harness; follow it from the front of the valve cover to the rear of the engine....There is a cylinder head stud/bolt head at the very back of the engine (drivers side behind valve cover) this stud/bolt head rubs through the harness, short circuits the wires and causes rough idle, bucking, misfires, hesitation and random codes. The symptoms sometimes begin after the engine is hot or has been running on the highway for awhile, and often come and go...It will take more than just a quick visual inspection....If the harness is resting upon this stud (or near it for that matter), if you don't allready have this problem eventually you will. I repaired the wire, wrapped the entire in harness in nylon loom, and put piece of vacuum hose over that stud...problems solved...
cjcyr8 is offline
post #8 of 10 Old 03-05-2013, 09:33 PM
wvracer821
wvracer821's Avatar
......ive been trying to track the same problems for a year ill be looking at this tomorrow.
Junk: 2000 WJ, 4.0L
Build Thread:
post #9 of 10 Old 03-06-2013, 01:00 AM
99WJ539918
+1 - a very common driveability issue I ran into at the dealership. Wires would rub the stud and short to ground on the block. The stud is on the back driver's side of the valve cover. I used a rubber hose to cover mine and it's been fine for years.
99WJ539918 is offline
post #10 of 10 Old 03-06-2013, 07:30 AM Thread Starter
ZB_WJ
Thanks, funny thing is, I think I read that thread a long time ago. I'm not having any codes, bucking or known misfires. Its more sluggish and loss of power. I am definitely going to check that and put some hose or duct tape on the threads. I completely forgot to do that.
ZB_WJ is offline
