4.0 bored throttle body - JeepForum.com
post #1 of 13 Old 05-13-2011, 07:14 PM Thread Starter
hoyt5885
i am looking at a bored throttle body from ebay and am wondering if it is worth it or not.
hoyt5885 is offline
post #2 of 13 Old 05-13-2011, 07:28 PM
the88thpianoman
2003 WJ
That depends largely on the price and the size of the bore.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #3 of 13 Old 05-13-2011, 07:45 PM Thread Starter
hoyt5885
price is 89.99 with a core and the bore is a 62/63mm bore
hoyt5885 is offline
post #4 of 13 Old 05-13-2011, 07:50 PM
Coolhand20th
Coolhand20th is offline
post #5 of 13 Old 05-13-2011, 08:25 PM
the88thpianoman
2003 WJ
I would say yes, then. But not unless you're upgrading other stuff as well. The idea is more air in, more air out. $90 is a good price, but you're not going to get much out of it without a high flow exhaust and air intake/cone filter. If you're really feeling adventurous, ported intake and exhaust channels in the cylinder head will make the most of the other upgrades too.
post #6 of 13 Old 05-13-2011, 10:02 PM
bushido7seven
yea what he said. first get a high flow muffler then cold air intake then the bore 62mm. Thats what I am going to do.
bushido7seven is offline
post #7 of 13 Old 05-14-2011, 06:59 AM
nickblack
I bought a 62mm ported TB and have felt no "seat of the pants" difference. I have a K&N intake and a high flow CAT and muffler, which I did first. The Cat & muffler made a difference, the TB did not. The thing with the ported TB is that if you don't also port the intake manifold, to match the TB, you won't get the added benefit. I was not willing to cut into the intake manifold, but if you are, I bet you will feel a difference.
nickblack is offline
post #8 of 13 Old 05-14-2011, 09:54 AM Thread Starter
hoyt5885
i have a cold air intake and high flow exhaust
hoyt5885 is offline
post #9 of 13 Old 05-14-2011, 10:32 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Not worth it. A 60mm throttle body is plenty for the 200hp a 4.0 puts out. If it were a higher-revving engine, I would say go for it. But for the low-end-torque, barely-makes-it-past-4000-rpm nature of the beast, its not going to make a lick of difference.
~Richard
billzcat1 is offline
post #10 of 13 Old 05-15-2011, 09:09 AM
nickblack
^^ agree with this rationale, I wasted my money out of curiosity. Us 4.0L owners are always looking for more power that is kind of impossible to get without stroking. As Narnwv says: "nobody with a V8 wishes they had an I6"
post #11 of 13 Old 05-15-2011, 05:35 PM
BransJeep
i have that throttle body as well as intake and exhaust and it really helped my wj out, saw about 1-2 mpg increase as well
-Brandon
4.0, 42re, 242
4.5 inch lift, front Ironman 4x4 adjustable CA's
RB1 and full J&L audio setup
Rola roof rack
BransJeep is offline
post #12 of 13 Old 05-15-2011, 06:01 PM
Bubba3200
Wouldnt a bored TB only benefit at full throttle? Dosent the computer limit or should I say control the air gas mix? If you put higher flowing injectors in they dont do much if anything cuz the computer will be programed to only flow a certain amount at a certain rpm. Like others have said a bigger bore TB is only part of a "system" that has to be done to make more HP. Just thinking out loud here....if you dump more air in then you need more fuel to burn. If you dump more fuel in then you need more air. I think these mods had more affect on non computer controlled cars of the past.
Bubba3200 is offline
post #13 of 13 Old 05-15-2011, 09:33 PM
rm2001wj
rm2001wj's Avatar
Yes, you are right. Until the throttle is wide open, the position of the throttle plate or butterfly controls and limits the amount of air going into the engine. A small increase in the diameter of the TB does does nothing during part throttle operation. The computer, with input from the O2 sensors, is going to cause the injectors to inject more or less fuel to match the air flow so that the A/F ratio stays near the 14.7:1 stoichiometric ratio.
rm2001wj is offline
port throttle body and MAF end, anyone done it K10roc WJ Grand Cherokee Forum 6 10-20-2011 04:58 PM
throttle body/where? 4.7 H.O. adamcorey WJ Grand Cherokee Forum 5 01-29-2011 11:36 PM
bored out throttle body RKOTAREK WJ Grand Cherokee Forum 30 12-20-2010 02:03 PM
4.7L throttle body Olese WJ Grand Cherokee Forum 4 10-02-2010 07:16 PM
72mm throttle body for the 4.7HO Bubba3200 WJ Grand Cherokee Forum 2 09-24-2010 11:38 PM
