32"s on WJ with 3" lift? - JeepForum.com
post #1 of 9 Old 03-16-2010, 07:59 AM Thread Starter
n8man1068
2003 WJ
Tried searching, couldn't find much.
I have an IRO 3" lift on my WJ. I'm currently running a 245/70/16 tire, and am thinking about bumping up to a 32". I imagine I'll have to trim the bumper a bit, and possibly extend the bump stops. Thoughts?
I'm currently using a 16" wheel with 4"BS. Would it be better to use a 15", or would the 16" give me a bit more ground clearance at the cost of bumper modification?
03 WJ IRO 3" lift, DT8000 shocks, Addco swaybars, JKS quick disconnects, IRO xfer skid, IRO adc control arms, Rola roof rack, Uniden 510xl+firestick 2, K&N drop in filter, Cragar soft 8's, Hankook Dynapro ATM/RF10tires
n8man1068 is offline
post #2 of 9 Old 03-16-2010, 11:03 AM
wonderbrd937
rim size wont change the height, its the tire that does that. and i had 32 inch bfg m/t on 5.75 or 6 inches of backspacing and i just had to barley trim the front bumper, i only had a 2 inch lift
99 WJ 4" SA lift
rolled fenders
35" bfg km2
tons of fabrication
wonderbrd937 is offline
post #3 of 9 Old 03-16-2010, 11:28 AM Thread Starter
n8man1068
2003 WJ
Ah. I wasn't sure if there'd be more clearance if I stayed on a 16" wheel, vs a 15".
I'd imagine then that with a 4" bs, i'd be rubbing more.
post #4 of 9 Old 03-16-2010, 11:31 AM
gman1322
gman1322's Avatar
I'm running the same rims with the IRO 3". IRO states you can run the 265 75-16's on STOCK RIMS. I ended up settling for the 265 70-16's and still had plenty of trimming to do because the backspacing pushed the tire out farther increasing the contact with the fender and bumper on turns. Had I stayed with the stock rims I could see how the 32's would work. I have a 3/4" coil spacer on the front too.
I still rub, but I am waiting for warmer weather to get out and do some more trimming. The MTR's I am running are not helping with the rub as they are 30.9".
265-70R16-GUARD-DOG-M-T-(D) - Retread Tires from TreadWright, Inc.
gman
2008 Jeep Liberty Sport
- 3.5" Rock Krawler, 245 75 16E Treadwright Warden AT's, Jet Stage One Chip
2007 Dodge Ram 1500 4WD
- Superchips 3865, 305 55 20 Nitto Grappler MT's, Hellwig sway bar, Powerwire, Sonnax Line Pressure booster, Bilstein Leveling Kit and rear shocks
gman1322 is offline
post #5 of 9 Old 03-16-2010, 11:35 AM
OFFRDWJ
I just put 265/75/16s on my wj with 4" of lift and front long arms (axle centered) and 16x8 unique 297s. No rubbing and no trimming.
At flex (going from driveway to road at angle) and wheel turned slightly there is about 1/4" space between tire and pinch seam.
OFFRDWJ is offline
post #6 of 9 Old 03-16-2010, 11:47 AM
wonderbrd937
the less backspacing you have the more it will sticj out. You should be fine with the 32s
99 WJ 4" SA lift
rolled fenders
35" bfg km2
tons of fabrication
post #7 of 9 Old 03-16-2010, 01:39 PM
Apollo21
i am running 32.25in on 4in of lift with a 3/4 spacer up front and mine are rubbing with stock bs i'm trimming a good amount
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread
SOLD
Apollo21 is offline
post #8 of 9 Old 03-16-2010, 04:57 PM
jamnjeep
I've got the IRO 3'' with 265x75 r16 with the stock rims and the only rubbing I get is on the rear shocks. With front sway bar disconnected some rubbing on front bumper.
1994 YJ under construction....
jamnjeep is online now
post #9 of 9 Old 03-16-2010, 05:29 PM
Diddy4895
These are 17" rubicons on 255/75/17 tires, 3" IRO and only took about 2 inches off the front bumper and no rub in back. Not wheeling material tho.
2000 WJ Laredo
IRO 3", Doetsch, Rubi Rims with 32's
Painted Cladding and Grille
Paul
SOLD!!!
Diddy4895 is offline
Have 2.5" Wj Coil Lift, Whats Needed For 4.5" Lift JEEPGUY09 ZJ Grand Cherokee Forum 22 08-13-2009 08:24 AM
Will shocks from 89YJ with 4"lift fit 95 Grand with 2" lift? bunk1967 ZJ Grand Cherokee Forum 9 04-05-2009 12:21 PM
WJ Lift starting 2" BB and working up to 3" and eventually 5" SSnipes ZJ Grand Cherokee Forum 6 04-01-2009 02:02 PM
1st Azusa Trip with 4"super lift "Verdict" wccf91 WK Grand Cherokee & XK Commander Forum 4 07-16-2007 10:23 PM
