3000 Mile trip across America!! - JeepForum.com
post #1 of 24 Old 04-24-2013, 08:40 AM Thread Starter
Valkyre
02 GC Overland 4.7HO 134000mi
Trying to get her ready for this trip any tips or suggestions I have in the works already a regular tune up plugs, oil, filters, new belt etc but I also have a tranny flush scheduled and installing a cold air and a new exhausts so anything else guys??
Valkyre is offline
post #2 of 24 Old 04-24-2013, 08:57 AM
cpratt247
Be careful with the flush. With your mileage you are sure to have issues with the transmission. I would find a shop that will let the fluid drain naturally for a few hours and then change the filter along with the new fluid.
Rear diff and the front diff (if you have one) fluid change. Don't pump it out, I'd take the covers off, inspect, clean out, new gasket and fluid.
You said you were replacing the belt, but keep the old one as a spare.
HAVE FUN!
There isn't anything better than the stench of a road trip.
cpratt247 is offline
post #3 of 24 Old 04-24-2013, 09:31 AM
WJ4x4LIFE
Make sure your tires, suspension, steering is in good order. Double check your coolant system that it does indeed hold @ 16psi and you do not have any leaks. You may want to ensure yourself with a overlook at the alternator and battery as well.
Have a AAA card with you at all times, hahaha. That is all I can think of right now, but I will probably add on later.
WJ4x4LIFE is offline
post #4 of 24 Old 04-24-2013, 09:58 AM
Darnice
Never "Flush" a tranny, that will kill it.
When you have the belt off, check your tensioner pulley and Idler Pulley bearing for roughness.
Also with the belt off, spin the water pump to check its bearing and check for any side to side play in it.
Darnice is offline
post #5 of 24 Old 04-24-2013, 10:15 AM
funkduck
2015 KL Cherokee
I don't see why you should be too concerned about the trans, these are stout units. Drop the pan, replace the filters, put the pan back and re-fill the trans. You won't get the fluid that's in the torque converter, but that's not really a problem if you didn't already have a specific concern. if your 02 Overland is like mine, there's already an aux trans cooler on it.
My advice is inspect all of your suspension bushings, the repetitive jiggling of a sustained highway drive could be different enough from their daily "groove" that they finish dying at the worst time. Be sure they're in fair or better shape before you head out. If you have any vibrations or out of balance tires/etc, get that resolved before leaving. I drive commercially as a major component of my job (just drove from Phoenix to Chicago to Dallas in the past week) so the above advice comes from direct experience.
funkduck is offline
post #6 of 24 Old 04-24-2013, 10:19 AM
PeteYJTJ
Check all your ujoints, front wheel bearings, etc. Check the spare, jack, etc. Make sure you can loosen all of your lugnuts also. It's no fun to get out in the middle of nowhere and realize that some gorilla put them on with an impact and you break your lug wrench trying to take them off.
Overall don't pretend something is ok if it's clearly not.
...And give us the details on the trip!!! From where to where? Why? What are your plans for stopping at attractions?????
Have a great trip! Road trips are the best.
Pete
88YJ:SOA/locked/35s/Superwinch=Wheeling Jeep.
04WJ:4.0/3"+10mm/Superwinch=DD & Expedition Jeep.
PeteYJTJ is offline
post #7 of 24 Old 04-24-2013, 10:39 AM
jorge1170
Wj
Road Trip!!!!!
That sounds like a great time. Enjoy and post pics of the trip
"We're all here for a funtime.....not a longtime!!!! Enjoy the ride!!"
jorge1170 is offline
post #8 of 24 Old 04-24-2013, 11:22 AM
journey50
2014 WK
Assuming Washington state where on the East coast are u headed? Ill be headed from Montana to New York here in may...2200 miles in my 02 overland...
Wash and wax her....clean cars look better and don't draw attention to them from troopers or highway patrol. Check everything over.... Make sure u have correct insurance cards etc... All your lights work including lic plate bulbs...
journey50 is offline
post #9 of 24 Old 04-24-2013, 12:00 PM
Double E
Double E's Avatar
Check spare tire pressure,
Grab 5-7 bottles of Techron and add every other tank.
Do oil change once you reach your destination.
Bring nitrile gloves for messy work.
Bring container of water, JIC.
Bring windshield washer fluid.
Have a good time!
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #10 of 24 Old 04-24-2013, 12:03 PM Thread Starter
Valkyre
I just changed the diff fluid and the front axle seals I toon the covers off and everything
And yeah I'm just doing a change in tranny fluid no flush
I replaced the front wheel bearings/ hubs when I did the seals
I plan on rotation and balancing the tires before i go
As for my trip I leave Virginia beach VA on June 20th and stop in TN, MO, WY, UT, and then end in oak harbor WA, I plan on rock climbing at a lot of places as we pass them other than that just drivin!
And thanks again guys for the tips anymore would be helpful if you forgot to mention something thanks again
Valkyre is offline
post #11 of 24 Old 04-24-2013, 12:08 PM Thread Starter
Valkyre
Have a good time!
What's techron?
Valkyre is offline
post #12 of 24 Old 04-24-2013, 12:34 PM
joeisalsocool
I just took a 2700mi round trip from NY to FL in February. I brought a spare bottle of every oil/liquid that the Jeep needs, jack stand, torque wrench, and most of what everyone else is saying here. Drove perfectly, just wore out one of the front wheel bearings, and front DS u-joint. Expect some post trip maintenance.
Have a safe trip!!
joeisalsocool is offline
post #13 of 24 Old 04-24-2013, 01:52 PM
Darnice
I annually drive from Canada to Florida and back(10 times so far). (Ah I-75 in Atlanta) and never had any problems. Just make sure your good with everything listed above and you should be good to go. Have Fun
Darnice is offline
post #14 of 24 Old 04-24-2013, 09:21 PM Thread Starter
Valkyre
Here is my plan when this tank gets down to half I'm going to put 3/4 bottle of seafoam in vac hoses then 1/2bottle in oil and whole bottle in gassed the rest of both in the gas tanks
Do the 60 plus etc etc big smoke show then drive the last half of tank and at that end first tune up starts
1 drain engine oil
2 install new spark plugs platinum
3 instal new injectors Bosch
4 fill engine with Mobil 1 full Syn with Bosch filter
5 flush coolant. And clean with cleanser and then use sealer and put it back on fill it and test it
6. If we have it install cold air intake
7 drain tranny clean and eg new gasket and filter
8 balance tires/ Tire pressure
9 clean car
10 install new exhaust if we have it
Valkyre is offline
post #15 of 24 Old 04-25-2013, 02:49 PM
dsodko
Balance all 5 tires. You never know if you'll get a flat on the Interstate! Torque all lug nuts to specs. Then check them after driving 8 hours. Highway vibration does strange things. Take extra fluid. Cheap insurance.
dsodko is offline
