Quantcast 30 minutes and more cargo room in the WJ - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > 30 minutes and more cargo room in the WJ
Old 09-18-2008, 11:15 PM   #16
CLNinja
another reason why ZJs are better
[color="#003300"]Matt[/COLOR]
[color="white"][CENTER][size="1"]
[url="http://www.jeepforum.com/forum/showthread.php?t=434081"][color="white"]Click Here For My Build Thread[/COLOR][/url]
[/COLOR][/SIZE][B]**September 2009 Grand Cherokee Of The Month**[/B]
[SIZE="2"][url="http://www.jeepforum.com/forum/forumdisplay.php?f=123"][color="white"]Colorado Jeep Club Member #88[/COLOR][/url][/SIZE][/CENTER]
CLNinja is offline   Reply With Quote
Old 09-18-2008, 11:40 PM   #17
UofOJeeper
Originally Posted by spife7980 View Post
i didnt know the Zj did either...
i always wondered why my hinge felt so unstable! i thought it was just really crappy and loose
1998 Laredo Special Edition V8
Toyo Open Country A/Ts - 245/70/R16
242 Swap
"A man who asks no questions, rarely has any answers"
UofOJeeper is offline   Reply With Quote
Old 09-19-2008, 12:09 AM   #18
QuadraTokn
1930 WJ
Originally Posted by theksmith View Post
an ez way to gain some storage space in the WJ...
all you need is:
- a socket set
- a torx bit
- (4) wire lock pins 5/16" x 2 1/4" (2 1/4" useable, 2 1/2" total length ussually)
- a drill and 21/64" bit (next step up from 5/16")
read on for details...
omg thats awesome Im doing this tomorrow.
I have a modified 1999 WJ and a stock 2001 WJ
Tread Lightly
Pictures
PARTED OUT 8 WJ Grand Cherokees ! ! ! ! ! !
QuadraTokn is offline   Reply With Quote
Old 09-19-2008, 07:49 AM   #19
CanadianZed-J
If you tumble a ZJ seat too fast it sometimes comes off the hinges. Clever design on the ZJ and clever idea and design on your WJ.
I regularily removed those parts from my ZJ when I took it camping. At 6'1", the bottoms removed and the front seats all the way forward there was more than enough room to sleep in it.
CZJ.
So I installed the flux capacitor but the Jeep just won't do 88 mph.
-'99 WJ Limited, 4.7, Patriot Blue, 2" BB, 31" Mall-Terrains, Pavement Princess
-'97 TJ, Stone White, 4" Superlift, 33" SSRs, lunchboxed rear, 12K Titan winch, and 2.5 litres of exhillirating performance.
CanadianZed-J is offline   Reply With Quote
Old 09-19-2008, 07:54 AM   #20
sandman
makes no sense that the wj seats didnt come removable from the factory.
1993 Jeep ZJ. 4.0
sandman is offline   Reply With Quote
Old 09-19-2008, 08:11 AM   #21
Double E
2000 Laredo V8
Double E's Avatar
We're here to make sense of it all!
2000 Laredo 4.7L Selec-Trac. 145K miles, Leather, 245 tires, tow package, crappy CD changer, full size spare, roof cross-rails & sunroof.
Changes & fixes: Rear Addco sway bar & greasble bushings, upgraded headlights, upgraded tail lights, new hood struts (replaced twice), new rear liftgate struts, new radiator (replaced 3 times), new oil pressure sending unit (replaced twice), 2 new speed sensors, 2 new door lock actuators, new ignition key cylinder, chrome front tow hooks, Mobil 1 Synthetic 5/30, Purolator Pure One oil filter, EBC slotted & dimpled rotors, EBC Greenstuff pads, new front shocks (replaced 3 times), new rear shocks (replaced twice),
new IRO steering stabilizer, new timing chain cover, new water pump, thermostat, new thermostat housing, new high pressure power steering hose, Michelin-X radials, new exhaust manufold studs & gasket on driver's side. Jeepforum.com sticker, Visit cobaltboatsforum.com when you can!
Double E is offline   Reply With Quote
Old 09-19-2008, 08:21 AM   #22
QuadraTokn
1930 WJ
it was one of the two things that I missed when I switched from a ZJ to a WJ. But now there will only be one thing that I liked better on my ZJ.
Tread Lightly
Pictures
Old 09-19-2008, 09:08 AM   #23
tylem28
and that would be??????
2.5 KOR BB W/ RS5000's & 245/75/R16
http://i247.photobucket.com/albums/g...ylem28/209.jpg
tylem28 is offline   Reply With Quote
Old 09-19-2008, 09:10 AM   #24
Fowlwing
on the XJ you lean it forward, then one side lifts str8 up and the other side is a pin that slides out with the seat... i take it out to have enough room to sleep in the back (6' 1")
yeah it sleeps pretty nice when you 6'2'' too
Cherokee... Mans jeep
Wrangler.... Mans jeep
SRT8......... Mans jeep
Liberty....... Womans jeep....
Fowlwing is offline   Reply With Quote
Old 09-19-2008, 09:24 AM   #25
QuadraTokn
1930 WJ
the body style. Every other aspect on WJ superior between the two.
Tread Lightly
Pictures
Old 09-19-2008, 09:54 AM   #26
Redstarlover
Great tip, I'm going to do mine week
2001 GC With Mods
4.0, 242, select trac,truetrac's F/R, 4,11s,Kevlar's 255/75/17 on JK, IRO transfer case skid, JKS sway disconnects and alot of other things.TR Front bumper, Mile Marker PE8000 winch, PIAA 510 lights, custom front drive shaft,Clayton's LA 6" lift,4" Drop pittman arm, WJ Front Chromoly/U-Joint Axle Conversion, XM,Tom Woods SYE kit rear drive shaft, Rusty Intake, Cobra 75 WX ST cb, IRO sliders,from 93003
Redstarlover is offline   Reply With Quote
Old 09-19-2008, 10:42 AM   #27
SVD
Very cool. However, my seat track is broken which causes it to rock backwards; the rear seat set up provides support so I don't fall backward when I drive
I really need to fix my seat because your set up is darn slick and makes more sense than about anything else I've seen online in a long time.
Well done!
SVD is offline   Reply With Quote
Old 09-19-2008, 11:32 AM   #28
nierace
2003 WJ
Nice
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
sira4x4.net North East Offroad Club
www.carolinadriveline.com
www.ironrockoffroad.com
kolak@aol.com
nierace is offline   Reply With Quote
Old 09-19-2008, 04:22 PM   #29
Best4x4
Best4x4's Avatar
Awesome idea! Where exactly did you get the wire lock pins? I'm doing this mod tomorrow as soon as I can track down the drill bit and pins! Thanks for the excellent write-up
Tad
Best4x4 is offline   Reply With Quote
Old 09-19-2008, 04:37 PM   #30
theksmith
theksmith's Avatar
2003 WJ
Tad
ace hardware had 3, then luckily home depot had the 4th one for me! the bit was just the next size up from 5/16" in a cheap harbor freight set i have.
theksmith is offline   Reply With Quote
Glock Forum
