30 minutes and more cargo room in the WJ
| 3/8" Amsteel Blue Winchline Available in Blue, Green, | Brand new! XJ Rear DIY Bumper from JcrOffroad! | Spartan Lockers FREE SHIPPING Excellent Prices |
#1 | |
an ez way to gain some storage space in the WJ...
all you need is: - a socket set - a torx bit - (4) wire lock pins 5/16" x 2 1/4" (2 1/4" usable, 2 1/2" total length usually) - a drill and 21/64" bit (next step up from 5/16") read on for details...
#2 |
when you flip the rear seats down, you have to flip the bottom part up, and you end up with this:
take the rear seat bottom out including the brackets, i think it was a 10mm: you might could do the next steps without removing the brackets, but i found it easier to just take the brackets off, can't remember which torx bit it was: drill out the end of the bracket hinge that is pressed over like a rivet: after you drill it, you may still need to use a punch to remove the hinge: drill out both parts of the bracket to 21/64" and verify the lock pins will fit, then repeat everything for the other bracket: bolt the back portion of the brackets back to the floor: now you have an ez to remove lower back seat, here it is installed: and here it is removed only on one side, demonstrating how much space you gain: |
#3 |
looks pretty sweet. . .Tryin to make the Wj like the ZJ.
Dylan-19 and Yearning 93 Rubigrand - Sold... :'( 95 Grand Cherokee Limited - 5.2 Mall Crawler 55 Willy's M38a1 - 231v6, 33" Super Swampers, D44 Full Floater Rear, Locked Front and Rear, 5.38 Gears, Viair OBA, Bilsteen 5100 shocks, Dana 18, Turbo 350, S10 Power Steering, Tilt-wheel, Full Cage, Flat Fenders.... |
#4 |
#5 |
That is the cleanest I've ever seen a WJ!!
Zak Formerly Default Jeeper #13 2000 WJ Limited 4.7 with stuff. Look left for the deets. |
#6 | |
Nicely done.
2004 4.0 Selec-Trac BB->Black Diamonds->General Grabbers Quote:
#7 |
man that is clean. i think i would seriously contemplate trading the orvis straight up for your wj. this is a very rare occasion.
-James Got to love an ORVIS guy... IRO 5.5", Front LA & Double Sheer TB, Rear Adjustable SA and TB, JKS Quick Discos, DT8Ks 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs JCR Stage 2 Sliders, IRO Trans Skid |
#8 |
#9 |
i didnt know the Zj did either...
#10 |
Yup. . .Tilt it forward and pick straight up. Pretty clever design.
#11 |
#12 |
Just a pin that sits on two "hooks". Mine always comes off track when i just tilt them foreward. But its handy when i want more space.
#13 |
#14 |
ahaha **** i didnt know the ZJ did that either, nice to know.
Alonzo "Casper" Gonzalez 1993 Jeep Grand Cherokee Laredo 4.0L Engine w/ 231 TC IRO 4.5" Lift on Kumho 31" MT
IRO frnt adj. track bar w/ mount Bilstein 5150 shocks JKS Quick Disconnects JCR 1 Ton steering Addco Front Sway bar Flowmaster muffler K&N air filter 2 Pro Comp 2 KC lights on KOR light bar Coleman roof rack Coming Soon! Gears and locker! |
#15 |
:ThumbsUp
So now XJs, ZJs, And WJs can share the love.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
