3" lift has finally all arrived - Page 2 - JeepForum.com
post #16 of 33 Old 03-14-2014, 12:30 PM
ChrisHager
Administrator
ChrisHager's Avatar
I had to trim a little with 245/75R16's at 4.5" BS...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #17 of 33 Old 03-14-2014, 12:51 PM Thread Starter
VBJeepWJ
2003 WJ
Originally Posted by ChrisHager View Post
Allow myself to quote... myself. These measurements are for the OME HD springs I installed.
I don't mind trimming the front fascia I actually don't even mind cutting the thing in half. I will also be making a build thread with my results and condition of all the parts as well as problems I ran into.
VBJeepWJ is offline
post #18 of 33 Old 03-14-2014, 03:33 PM
Johnyre
Originally Posted by VBJeepWJ View Post
I think 2.75 is reasonable results from a 3" lift. I just have to make sure the 265 75 16s fit.
You are going to have to trim A lot more then you think. Including the rear bumper. Ask me how I know
As I roll down the trail,I hope my traction will not fail.But if I spin & begin to slide,please dear lord protect my ride
https://
http://fortcollinswheelers.com
Johnyre is offline
post #19 of 33 Old 03-14-2014, 03:57 PM Thread Starter
VBJeepWJ
2003 WJ
Do you have the ome hd springs
VBJeepWJ is offline
post #20 of 33 Old 03-14-2014, 06:17 PM
Johnyre
No But I am sitting at around that hight and know because I had to, almost ripped the bumper off....
https://
Johnyre is offline
post #21 of 33 Old 03-14-2014, 06:23 PM Thread Starter
VBJeepWJ
2003 WJ
whats your hub to fender measurements?
VBJeepWJ is offline
post #22 of 33 Old 03-14-2014, 07:48 PM
Johnyre
Just shy of 21 in the back and 21 flat front
https://
Johnyre is offline
post #23 of 33 Old 03-15-2014, 08:03 AM
kkbenco
2003 WJ
OMES imo will NOT give you 3" of lift
I have heard mixed reviews on this. Kolak has sworn up and down that it will give a 3 inch lift.
I have went thru 2 sets of ome hds in my wj from kolak. ABSOLUTLY no way did I get 3" of lift. First set 1.5 ish second 2 ish. Second set, ride so stiff, worse than my 03 f350. Beware, go direct to IRO.
kkbenco is offline
post #24 of 33 Old 03-15-2014, 08:23 AM
ChrisHager
Administrator
ChrisHager's Avatar
I love my OME HDs. Turned out perfect for me on the first try...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #25 of 33 Old 03-15-2014, 09:27 AM Thread Starter
VBJeepWJ
2003 WJ
I have heard nothing but good things about them. I have to think sometimes there is operator error when installing the lifts. I have done a lot of research on this and it seems like if the person has an extensive review the results are good. If the results aren't good it is someone who doesn't sound too bright ranting and raving. I am not insulting anyone just an observation I have had.
VBJeepWJ is offline
post #26 of 33 Old 03-15-2014, 10:41 AM
veiri86
2003 WJ
In my opinion after short experience with few items from different manufacturers, it is all a matter of luck and these manufacturers QC is terrible as you can find quite few pairs of springs with different length or different rating (just my opinion)
Sent from ME
R.I.P ratmonkey
Build thread:
01' 4.7 Limited WJ 5" lifted, Rubicon Express 4.5" coil springs with IRO critical path setup and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), JKS HD tie rod (MOOG problem solver Ends), JKS HD drag link (Moog Probel solver Ends), 4.56 Yukon ring and pinion, Moog HD SSD107 Steering Stabilizer, IRO Front drive shaft conversion, Stillen slotted rotors all around with Stillen brake pads, IRO adjustable A-Arm, 3" all the way Kolak Exhaust with High flow Magnaflow Cat. Converter and Flowmaster Super 50 Muffler, 285/70R17 AT Kumho (33") on 17" BlackWheel rims 909B, K&N Cold air intake, Four nozzles Bosch injectors, and Flashpaq 3780.
03' 4.7 H.O WJ 3" lifted, OME HD with 0.5" Coil spacers and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), Moog Problem solver TRE's, IRO Front drive shaft conversion, IRO adjustable A-Arm, High flow magnaflow mini cats, high flow magnaflow cat, Flowmaster Super 44 muffler, 265/65R17 AT Yokohama on 17" Rays rims, and Flashpaq 3780
veiri86 is offline
post #27 of 33 Old 03-15-2014, 12:48 PM
Tollmtn
2016 JK Wrangler
The variables such as model, engine, the condition and type of the OEM springs and shocks, being replaced, if the spring isolators are replaced or even the same brands are used, if the shocks are monotube gas or hydro all make a difference in ride height. Blanket statements on what to expect lift wise can not be made because of the variables.
Two people in this thread alone said they only gained 2" of lift. OME list both the light and HD springs as giving 1.5" of lift. Frankly the results with them have been all over the place in about every thread that pops up.
Chris gained 2.75" in the front and 2" in the rear. So it boils down to 3/4" difference in the front from some other members still his AVERAGE lift only amounts to 2 3/8" so well below 3". Don't forget this is between different sets of springs, OME springs have changed in ride height in the past pointing to the possibility of questionable quality control.
So IMO. If a person is kind enough to share his experience with the parts and they differ from a person preconceived notions, he would be well served to listen to them rather than question their IQ.
Tollmtn is offline
post #28 of 33 Old 03-15-2014, 03:11 PM
kkbenco
2003 WJ
Did you get 3"?
I have finally received all of the components for my 3" OME HD lift and I felt the need to tell everyone because I have been wanting it for 3 months now. I am curious if there is anything people would like me to take pictures of while doing it or to look for while doing it. I know there is a lot of literature out there, but cant hurt to have more and I would be glad to help anyone out.
I have gone thru 2 sets of ome hds from Kolak, no way 3" lift is possible from them. New isolators every time, got 2" max running 5100 bills. Ride is like a tank. Choose wisely. iro
kkbenco is offline
post #29 of 33 Old 03-15-2014, 03:29 PM
WJLTD2001
I have the ome HD springs with 10mm ome spacers all around from Kolak and measure 21.5" hub to fender all around.
WJLTD2001 is offline
post #30 of 33 Old 03-15-2014, 03:51 PM
ChrisHager
Administrator
ChrisHager's Avatar
You aren't doing something right. That is so weird. Using isolators helps... :-)
That being said, if you truely had a bad experiece with OME, it's totally understandable giving them a negative review. IRO is a great lift as well. Either will be a great choice.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
