3" lift has finally all arrived - JeepForum.com
post #1 of 33 Old 03-13-2014, 05:30 PM Thread Starter
VBJeepWJ
2003 WJ
I have finally received all of the components for my 3" OME HD lift and I felt the need to tell everyone because I have been wanting it for 3 months now. I am curious if there is anything people would like me to take pictures of while doing it or to look for while doing it. I know there is a lot of literature out there, but cant hurt to have more and I would be glad to help anyone out.
VBJeepWJ is offline
post #2 of 33 Old 03-13-2014, 05:53 PM
cr8zynelly
What components? How many miles on your Jeep?
cr8zynelly is offline
post #3 of 33 Old 03-13-2014, 06:07 PM Thread Starter
VBJeepWJ
2003 WJ
I got the OME HD springs, ProComp 9000 shocks, Iron Rock adjustable trackbar and rear extended endlinks, new steering stablizer, and finally new spring isolators
Also new tires and rims are procomp flat black rock crawler series 16" rims and goodyear duratrac 265/75/16 tires
VBJeepWJ is offline
post #4 of 33 Old 03-13-2014, 06:15 PM
MuddyWJ
Create a build thread. That way others that search can use any information they deem worthy.
MuddyWJ is offline
post #5 of 33 Old 03-13-2014, 06:33 PM Thread Starter
VBJeepWJ
2003 WJ
I just wanted to post about it because im excited it has all finally come in, and maybe someone about to do a lift would like to know what certain parts look like on a 110k mile vehicle. IDK just bored and trying to help out.
VBJeepWJ is offline
post #6 of 33 Old 03-13-2014, 11:33 PM
Johnyre
I bet you are! I am waiting for my jks track bar to finally come so I can put my new springs on
As I roll down the trail,I hope my traction will not fail.But if I spin & begin to slide,please dear lord protect my ride
https://
http://fortcollinswheelers.com
Johnyre is offline
post #7 of 33 Old 03-14-2014, 02:21 AM
veiri86
2003 WJ
Before you start the job check the measurements hub to fender and check the same after the installation. The OME HD gave me something like 2" lift compared to the stock height when the Jeep was brand new. Stock measures 18" and after OME HD it sits at 20" with fresh coil isolators all around.
Sent from ME
R.I.P ratmonkey
Build thread:
01' 4.7 Limited WJ 5" lifted, Rubicon Express 4.5" coil springs with IRO critical path setup and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), JKS HD tie rod (MOOG problem solver Ends), JKS HD drag link (Moog Probel solver Ends), 4.56 Yukon ring and pinion, Moog HD SSD107 Steering Stabilizer, IRO Front drive shaft conversion, Stillen slotted rotors all around with Stillen brake pads, IRO adjustable A-Arm, 3" all the way Kolak Exhaust with High flow Magnaflow Cat. Converter and Flowmaster Super 50 Muffler, 285/70R17 AT Kumho (33") on 17" BlackWheel rims 909B, K&N Cold air intake, Four nozzles Bosch injectors, and Flashpaq 3780.
03' 4.7 H.O WJ 3" lifted, OME HD with 0.5" Coil spacers and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), Moog Problem solver TRE's, IRO Front drive shaft conversion, IRO adjustable A-Arm, High flow magnaflow mini cats, high flow magnaflow cat, Flowmaster Super 44 muffler, 265/65R17 AT Yokohama on 17" Rays rims, and Flashpaq 3780
veiri86 is offline
post #8 of 33 Old 03-14-2014, 05:28 AM Thread Starter
VBJeepWJ
2003 WJ
Sent from ME
I have heard mixed reviews on this. Kolak has sworn up and down that it will give a 3 inch lift.
VBJeepWJ is offline
post #9 of 33 Old 03-14-2014, 06:15 AM
jamesrw30
I ordered the three inch IRO lift from Kolak. Have gotten my procomp shocks, disconnects, and isolators in. Waiting on my trackbar and the lift kit from IRO. Can't wait to get mine on. Definitely would like to hear about any snags or "gotcha" moments you run into.
jamesrw30 is offline
post #10 of 33 Old 03-14-2014, 06:21 AM Thread Starter
VBJeepWJ
2003 WJ
I was gonna go with the iro lift but i guess the springs are backordered.
VBJeepWJ is offline
post #11 of 33 Old 03-14-2014, 09:10 AM
Johnyre
The OME Hd kit is 3 inches while the med kit is about 2-2.5
https://
Johnyre is offline
post #12 of 33 Old 03-14-2014, 09:15 AM
ChrisHager
Administrator
ChrisHager's Avatar
Allow myself to quote... myself. These measurements are for the OME HD springs I installed.
Originally Posted by ChrisHager View Post
I also finally measured the height the lift and tires gave me. The only 'oops' was the "Original" was measured on 1/4 tank of gas and the "New" was measured with a full tank of gas.
Center Hub to Wheel Well
Front Driver
Factory: 18"?
Original: ~17 3/4
New: 20 3/4"
Front Passenger
Factory: 18"?
Original: ~18"
New: 20 3/4"
Rear Driver
Factory: 19"?
Original: ~18 1/2"
New: 20 3/4"
Rear Passenger
Factory: 19"?
Original: ~18 3/4"
New: 20 3/4"
Total Height Difference (Measurement from floor to wheel well including tire height in "New" measurement):
Front Driver
Original: 31 1/4"
New: 35"
Front Passenger
Original: 31 1/2"
New: 35"
Rear Driver
Original: 32 1/4"
New: 35"
Rear Passenger
Original: 32 1/4"
New: 35"
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #13 of 33 Old 03-14-2014, 09:23 AM
veiri86
2003 WJ
My HD kit gained me 2" only. And concerning the MD, as I know OME is having problems matching the front with the rear length and the right with the left, I can't remember exactly what is the issue, but due that issue some vendors when they sell the MD kit they mix MD front with HD rear or vice versa. Google OME MD lift kit for WJ in this forum and you will read about the issue in details.
Sent from ME
R.I.P ratmonkey
Build thread:
veiri86 is offline
post #14 of 33 Old 03-14-2014, 11:00 AM
brewcity1
I would love some info, pictures, or a build thread on this. I am about to put my IRO lift on, just waiting on the Bilsteins! Any help would really be appreciated by me...and I am sure others.
2004 Grand Cherokee Limited 4.7L
General Grabber AT2's 255/65/17
1" Addco rear sway bar
brewcity1 is offline
post #15 of 33 Old 03-14-2014, 11:03 AM Thread Starter
VBJeepWJ
2003 WJ
I think 2.75 is reasonable results from a 3" lift. I just have to make sure the 265 75 16s fit.
VBJeepWJ is offline
