3/4 ton Grand Cherokee - JeepForum.com
post #1 of 47 Old 07-12-2010, 07:32 PM Thread Starter
peters
1946 CJ3A
Has anyone replaced the factory rear springs on a 99-04 Grand Cherokee for a heavy duty spring of some sort. I am dong some towing this summer and want a bit beefier rear susp.
peters is offline
post #2 of 47 Old 07-12-2010, 07:40 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
air bags.
but, the grand is limited in its towing ability by its wheelbase and not being full frame more than it's suspension and motor.
ratmonkey is offline
post #3 of 47 Old 07-12-2010, 07:54 PM
comptiger5000
As Ratmonkey said, one of the biggest limits to the towing capacity of a Grand is its size and weight. Being unibody doesn't help either.
comptiger5000 is offline
post #4 of 47 Old 07-12-2010, 08:31 PM
WJChris
WJChris's Avatar
Its not a matter of only the springs. It's a matter of the unibody structure, axles, etc.
The GC is rated at 5000 pounds towing, what more do you need?
WJChris is offline
post #5 of 47 Old 07-12-2010, 08:34 PM Thread Starter
peters
1946 CJ3A
well I tow a 14' tandom with my old willys mud racing only truck on it and shes a bit tounge heavy
peters is offline
post #6 of 47 Old 07-12-2010, 08:57 PM Thread Starter
peters
1946 CJ3A
Im gonna jack my own thread to let everyone know that if I cant effectivly beef the rear susp up a bit the truck will be for sale.
2000 Grand Cherokee, ATX Preditor Rims, 2.5'' susp lift, Black Grill, Bush Guard w Lightforce Lights, Alpine sterio front to back, custome exhaust, Upgraded brakes, 4.7 V8, auto, power everthing, Very well maintaned truck, 218 000kms. Very litle for safty, Only thing it needs is new chain in T-case.
Located in Fort Frances, Ontario asking $6000 obo. or trade for truck.
peters is offline
post #7 of 47 Old 07-12-2010, 09:02 PM
JTM1
1988 XJ Cherokee
Why don't you just try loading your truck differently on the trailer to reduce your tongue weight?
Justin
88 XJ-Lifted, Locked, and on Jackstands
69 CJ5-In peices
JTM1 is offline
post #8 of 47 Old 07-12-2010, 09:06 PM Thread Starter
peters
1946 CJ3A
trailer is designed so that not possible, i dont wanna get rid of trailer, its outfitted nice with with my generator and compressor and jacks and chains and all my gear
peters is offline
post #9 of 47 Old 07-13-2010, 01:14 AM
ZJ5point2GCL
if its just a tongue weight issue, get an equalizer hitch, you should have one anyways with such a short wheel base vehicle
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #10 of 47 Old 07-13-2010, 05:16 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
you're not towing it right. you need a weight distribution hitch and/or a much better trailer for what you're trying to do.
post #11 of 47 Old 07-13-2010, 07:57 AM Thread Starter
peters
1946 CJ3A
I didnt ask if i "was doing it right", I was only wondering about heavier springs. A new trailer will cost 2-3k as opposed to new springs which will run $100-300. Now you can see why I was pondering the idea. I guess if noone knows Ill ask around another jeep forum,
peters is offline
post #12 of 47 Old 07-13-2010, 08:53 AM
ras2001wj
ras2001wj's Avatar
OME Hd Springs?
And fwiw, 6k, even Canadian is steep for a 2000
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
ras2001wj is offline
post #13 of 47 Old 07-13-2010, 08:55 AM
narnwv
narnwv's Avatar
with the V8, your capacity is 6500#s with 750#s tongue weight, with weight distribution hitch. WJ jeeps says 25' trailer maximum. I think you would be okay with the weight distribution hitch, which you should be using on any vehicle with that much weight anyways.
~Aaron
narnwv is offline
post #14 of 47 Old 07-13-2010, 08:57 AM
comptiger5000
The OME HD springs, or air bags in the rear springs would help a bit. Definitely get a weight distribution hitch. The WJ V8 is rated to tow 6500 pounds, with 750 pounds max tongue weight. I'd also want trailer brakes if you don't already have them. It should do fine with the weight as long as you have it set up right.
post #15 of 47 Old 07-13-2010, 09:00 AM
ajamison
ajamison's Avatar
1991 MJ Comanche
i know this is a long shot and ill get some crap for saying it, but if you truly want to keep your jeep and beef up the rear susp, consider converting to the rear leaf springs? may be a better set up for towing than coils, but i could be wrong
Jamison
ajamison is offline
swapping a grand cherokee rearend for a cherokee dana 44 is it strait bolt in kojak70 ZJ Grand Cherokee Forum 2 11-01-2009 11:44 PM
Will A 242 Transfer Case From A 90 Cherokee Fit In My 99 Jeep Grand Cherokee.?? squirrly ZJ Grand Cherokee Forum 8 03-05-2009 05:55 PM
Trailer Hitch swap from Cherokee to Grand Cherokee hitchikerjoe ZJ Grand Cherokee Forum 4 09-29-2008 05:02 PM
1993 grand wagoneer/grand cherokee, alarm problem help! greenday1425 ZJ Grand Cherokee Forum 3 03-03-2007 11:16 AM
Grand Cherokee vs. Grand Wagoneer exhaust Wiley ZJ Grand Cherokee Forum 2 12-31-2005 07:15 PM
