26.42 mpg US / 31.7 Imperial (Canada) - JeepForum.com
post #1 of 29 Old 10-31-2012, 09:52 AM Thread Starter
jimwww
jimwww's Avatar
Wj 26.42 mpg US / 31.7 Imperial (Canada)
Hi Guys,
I just did a long trip in the last two days. I measured the distance travelled to Kelowna BC from Vancouver and back. I filled the tank. Got to Kelowna and refilled the tank - wrote down the mileage. Did the same thing back in Vanc. Filled the tank at the SAME spot I filled it before. (did not use the gas gauge as a measure for mileage.
I did not drive it over 65mph, many times drove it at 55mph as I went up long mountain roads (Same highway you see on the tv series 'Highway thru hell')
8.9 liters per 100 km is what I averaged. That equals 26.42 mpg or in Canada 31.7 mpg because our gallon is larger.
New spark plugs, 6cyl, 230,000 km on it, needs a new fuel filter, does have a new air filter on it, new snow tires for trip - 245/70/16, coolant was replaced before trip.
In the city I average 500km out of a tank (60% of that is hwy), over 750km on highway.
First really long trip I did in it. I really love driving this Jeep. Just as nice as my WK but 22,000 dollars cheaper.
NOTE: I was in 2wd for 4/5ths of this trip. I was in 4wd Full time for 1/5th of this trip. I have Selectrac. Used only Chevron Gas Octane 97.
1999 Jeep GC Limited ( WJ ) V8
jimwww is offline
post #2 of 29 Old 10-31-2012, 10:19 AM
pileofAces
2005 WK
pretty unbelievable numbers considering you were also driving mountain roads.
Black WK Club #165
2005 WK Laredo 4.7 V8 4x4. 245/70-17 General Grabber AT2.
pileofAces is offline
post #3 of 29 Old 10-31-2012, 10:41 AM
gcjeeping
^ x2
Through the mountains and 4wd at some point and a high mileage WJ. Pretty hard to believe. When new they only claimed 19 mpg on a good day.
_____________
gcjeeping is online now
post #4 of 29 Old 10-31-2012, 11:27 AM
mycreativename
I'm really finding it hard to believe, unless you were going down the mountain roads. From here (Buffalo) to Pittsburgh, I get 18mpg going one way and 23ish going the other, because one way is up hill and the other is down, perhaps that's what boosted your numbers so high.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #5 of 29 Old 10-31-2012, 02:18 PM
alfaitalia
I really struggle to believe that. Under those conditions I would struggle to beat that with my CRD! Think you might need a new calculator!!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #6 of 29 Old 10-31-2012, 05:52 PM Thread Starter
jimwww
jimwww's Avatar
Ya I know.. but I have had a lot of jeeps - never with a Selectrac.
The numbers though now using a canadian converter shown with a larger canadian gallon:
On the way up: 379km and used 44 liters.
On the way down: 350km and used 39 liters.
I thought I figured it out correctly using
http://www.tdiclub.com/misc/conversions.html but I think it is different using USA gallons. So that means approx 20 mpg usa or 24 mpg cdn.
I used http://www3.telus.net/findNchoose/mpg.html
jimwww is offline
post #7 of 29 Old 10-31-2012, 06:06 PM
gcjeeping
First pic calculations show...
379 kilometers=235.5 miles
44 liters=11.6236 US gallons
235.5 Miles / 11.6236 US gallons = 20.26.... MPG
Second pic calculations show...
350 Kilometers=217.48 miles
39 liters=10.3027 US gallons
217.48 miles / 10.3027 US gallons =21.10... MPG
452.98 Miles round trip / 21.9263 US gallons = 20.65... MPG
_____________
post #8 of 29 Old 10-31-2012, 06:12 PM
Dominic123
Those are impressive numbers! My WJ 4.0L is way far behind yours. I barely meet 13 MPG (19 L/100km). No towing, no 4wd at 100km/h. What's wrong with my truck or what did you do to your Jeep?
Dominic123 is offline
post #9 of 29 Old 10-31-2012, 06:16 PM Thread Starter
jimwww
jimwww's Avatar
Right.. and Canadian gallon is 1/5th larger than a USA gallon making them both correct at 20.26 mpg USA and 24.2mpg Canadian. For what it is worth - I hate Metric.
jimwww is offline
post #10 of 29 Old 10-31-2012, 06:16 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Originally Posted by gcjeeping View Post
235.5 Miles / 11.6236 gallons = 20.26.... MPG[/B][/URL]
Still, 20 mpg is spectacular.
In the garage: M1 4bbl
McCloudsZJ is offline
post #11 of 29 Old 10-31-2012, 10:03 PM
elcorvino
2003 WJ
Not if you don't drive like a kid. Lol
I rock 55 mph w/ cruise control and consistently get 22 mpg with all highway driving.
elcorvino is offline
post #12 of 29 Old 10-31-2012, 10:04 PM Thread Starter
jimwww
jimwww's Avatar
I do drive it gently - especially on a long trip. When I first got it I did put in a bottle of fuel injector cleaner. I have not changed the PCV valve yet.
jimwww is offline
post #13 of 29 Old 10-31-2012, 10:10 PM
elcorvino
2003 WJ
I6 stock height? I'd figure out what's wrong with it then, unless your hwy driving is @ 75 or 80 mph. lower mpgs would be expected if your rockin 2200+ RPMs down the road.
post #14 of 29 Old 10-31-2012, 11:01 PM Thread Starter
jimwww
jimwww's Avatar
If I recall 2000rpm at 55/60mph I think. I have 3.55's. I have the build sheet. No Lift yet.
jimwww is offline
post #15 of 29 Old 10-31-2012, 11:23 PM
elcorvino
2003 WJ
Ouch. Something is wrong. 55 mph with the i6 and 3.55's... I'm at or just above 1500 RPMs.
gas , improve , mpg
