247 Quadra-Drive - JeepForum.com
post #1 of 4 Old 03-28-2012, 04:43 PM Thread Starter
bgjhnsn99
247 Quadra-Drive
Tried to search with no luck. Have 2001 Limited, 4.7, 247, Quadra-Drive. 2-1/2" lift and 33" tires.
In 4lo, rear tires spin and both front tires just wobble a little, but don't spin.
I thought the front and rear were supposed to be locked in 4WD.
Any ideas?
bgjhnsn99 is offline
post #2 of 4 Old 03-28-2012, 04:57 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Broken chain or stripped sprockets. Or there could be a front diff issue. Have you verified that the front driveshaft spins in 4LO?
~Richard
billzcat1 is offline
post #3 of 4 Old 03-28-2012, 05:14 PM Thread Starter
bgjhnsn99
is there any easy way to do that? Or will you lay under it while i stomp on gas?
post #4 of 4 Old 03-28-2012, 05:16 PM
billzcat1
2003 WJ
Put it up on jackstands and you can check yourself. Or you could even remove the driveshaft and just jack the rear, check if the transfer case yoke spins.
~Richard
Quadra-Trac vs Quadra-Drive grovesj2 WJ Grand Cherokee Forum 48 06-24-2014 12:48 PM
Quadra-Drive or Quadra-Trac in UK 4wheeluk WJ Grand Cherokee Forum 0 06-28-2011 02:53 PM
Quadra Drive vs Quadra Trac 2. Possible swap Kennedy WJ Grand Cherokee Forum 32 01-11-2011 02:13 PM
quadra trac II v. quadra drive diver110 WJ Grand Cherokee Forum 9 12-14-2010 06:59 PM
