245/75/16 On stock WJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > 245/75/16 On stock WJ
Savvy FOX IFP 4" Lift Shocks in StockOnly 2 Days left to win $3,800 Jeep Parts!Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 12-18-2014, 11:56 AM   #1
THEBAD1
Question guys,
Looking to do a 2" lift come spring. But, I need new tires now and see a lot of you guys have 245/75/16 or 265/75/16. Question is, will these tire size work on a stock WJ without tire rub?
Thanks for any info!
THEBAD1 is online now   Reply With Quote Quick reply to this message
Unread 12-18-2014, 11:58 AM   #2
ChrisHager
//Mr_Untouchable
ChrisHager's Avatar
It has been rumored that a 245/75R16 tire on stock rims (without wheel spacers) will work for on road driving with minimal rubbing on the front fascia.
A 265/75R16 will rub quite a bit.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 12:09 PM   #3
derekmac
derekmac's Avatar
Without tire rub, no. As Chris said, the 245 will give minor rubbing on road, and quite noticeable off-road.
2002 WJ Olympics Commemorative Edition
32" BFG Mud Terrains
2" BB
Build thread.
derekmac is online now   Reply With Quote Quick reply to this message
Unread 12-18-2014, 01:24 PM   #4
pmdowd6
I rubbed the front bumper with 245/75r16 on a 2" bb with my old WJ. No way in hell I would have tried it without the bb.
pmdowd6 is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 01:43 PM   #5
derekmac
derekmac's Avatar
I can't remember if I had my bumper trimmed when I had them put on mine without the BB, or if I trimmed after getting the BB. Come to think of it, it might of been before. I have the fog lights cut out now as I wheel without the swaybar connected, and it would rub pretty bad when tucked.
2" BB
Build thread.
Unread 12-18-2014, 04:34 PM   #6
losttech
losttech's Avatar
Why don't you search craiglists for a set of 16inch steel rim takeoffs from a JK they come with 225/75/16 and you can get a whole set with tires for 200-300 or less if you look around.
run those for however long and when you get the money for a good lift and tires sell them and do your lift.
If not biggest I would go is 245/70/16 I know that size fits it was a stock option and I had them before I don't think they would look bad with a 2inch lift either mine look a little big without a lift.
2000 Jeep grand Cherokee
I6, selectrac, dana 30 front 44a rear
Stock not lifted.
losttech is online now   Reply With Quote Quick reply to this message
Unread 12-18-2014, 07:51 PM   #7
THEBAD1
So, your running the 245/70/16 with no lift?
Unread 12-18-2014, 08:26 PM   #8
jra8858
I am
jra8858 is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 08:33 PM   #9
Jeepin333
2003 WJ
I have been running 245/75/16 duratracs(fairly meaty) on stock rims no spacers no lift since 2010 with only slight rub during full lock to the right in reverse and same offroad I stuff these tires all the way up into fender wells without any major rub. only damage is plastic fender liner burning through, but thats after four years of putting it through hell. i recommend going as big as you can expecially if your going to lift. if you don't mind being mindful of how far you turn while backing up for a few months.
Jeepin333 is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 08:48 PM   #10
losttech
losttech's Avatar
Yes had those on stock now I have 245/65/17 which is the same size really 29.5, no lift some say you can go the next size up but what I got seems to be the biggest I would even try without a lift.
Stock not lifted.
Unread 12-19-2014, 08:51 AM   #11
offroading.net
offroading.net's Avatar
I have run them on a stock WJ. You need to cut about 2" from the bottom lip of the front bumper. Never had it offroad without a lift but expect some more bumper trimming would be required. Rear was fine.
Steve Wright
1999 4litre WG Limited, 4"f-4.5"r IRO springs, IRO front long arms, IRO adjustable rear a-arm & LCAs, IRO adjustable RHD trackbar, XJ 242 transfer case, 3.91 Diesel Quadradrive axles, 235-85-16 Grabber AT2's Build thread
2003 2.8CRD KJ Limited
Previous Jeeps - 8 XJs, an MJ, a WJ, a TJ & a KJ
steve@offroading.net
www.offroading.net
www.rcmodelflying.com
www.oldchadscider.co.uk
offroading.net is offline   Reply With Quote Quick reply to this message
Unread 01-03-2015, 06:40 PM   #12
THEBAD1
Thanks for the info guys, Think I'm going to go with the 245/70/16 as Losttech mentioned.
Unread 01-03-2015, 06:46 PM   #13
seraph_rapture
I put on a set of 245/75/16 BFG AT earlier this week and they're working out fine with no lift. Was some rubbing on the plastic fender liner but I suspect that's because it was missing a couple screws. Lift should be coming later this week.
From 2.5/AX5, 30" Geolander, 2" BL
TO 4.0/AW4, 2.5 OME SOA, 5/8" boomerangs, 8.8 Aussie locked, D30 CAD eliminated, 35" Radial Rover, JCR 4x4 front and rear bumpers, ENGO 9000, Volvo e-fan, TJ rock rails, etc etc.
seraph_rapture is offline   Reply With Quote Quick reply to this message
Unread 01-03-2015, 08:46 PM   #14
C101Commando
I had 245/75/16s with no lift for a few weeks, it was tight but useable. A set of cheap spacers made it much better..
03 WJ, 4.7 Limited
C101Commando is offline   Reply With Quote Quick reply to this message
Unread 01-05-2015, 06:14 PM   #15
Planetcat
Wj
Same here, but I have a 2.75" spring lift. They just fit on/off road. Now I run 265/70R16's and had to trim the front fascia. I run Spidertrax wheel spacers on stock silverblade wheels too. I can't imagine either of those two tire sizes working without mods on a stock WJ.
2004 WJ 4.7L, 1959 CJ-5, 1990 XJ Limited (sold), 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline   Reply With Quote Quick reply to this message
