242 transfer case swap to a 247 - JeepForum.com
post #1 of 3 Old 06-24-2013, 09:22 PM Thread Starter
subford
Okay, so I want to do a 242 transfer case swap because my 247 is shot.
I need to know about the drive shafts. Are the drive shafts the same length front and rear on the 242 and the 247?
The 242 in from a 1999 WJ and mine is also a 1999 WJ.
The 242 is out of a 4.0L and mine is a 4.7L
Will the input shaft be the same? If not can I swap them?
Thanks
1999 WJ Jeep Grand Cherokee Laredo Sport Utility 4D
4.7L, 4WD Automatic, Quadra-Trac II
Bill K
subford is offline
post #2 of 3 Old 06-24-2013, 09:28 PM
USFORCES
You need the rear shaft that came with the transfer case.
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline
post #3 of 3 Old 06-24-2013, 09:47 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Front drive shaft is the same, rear will need to be swapped to the same shaft that came out of your 242 donor jeep. The input shaft will also need to be swapped out.
~James
ezflip is offline
