231 or 242 transfer case swap - JeepForum.com
post #1 of 26 Old 12-07-2010, 09:00 PM Thread Starter
Mud_Crazy
Ok so i was looking into transfer case swaps. i know that the 242 is pretty straight forward. how ever i found that a 231 (common-trac) could be done as well, with minor modifacation. question is what is the difference between the 2.
SILVER&BLACK 02 JEEP GRAND CHEROKEE 4.7L V8 HO, Clayton 6" liftT w/ Bilstien 5100's and 2in pucks , 37X12.5 Nitto Trail Grappler M/T's on red and black Creeper Locks, front and back Dana 60 w/ ARB lockers, Chromolly shafts and 5.13 gears, ARB compressor, Flowmaster 50 exhuast, K&N FIPK, IRO front bumper and flares, and Cobra 29NW with firestick antenna.
Mud_Crazy is offline
post #2 of 26 Old 12-07-2010, 09:42 PM
esoxhntr
2008 WK
selec-trac (242) has full time 4wd.
command-trac (231) does not. "only" part time 4wd.
'97 XJ. 4.0. *sold*
'01 WJ. 4.7. *sold*
'08 WK 3.0 CRD. Camping, Towing, Fishing Machine v3.0
esoxhntr is offline
post #3 of 26 Old 12-07-2010, 09:51 PM Thread Starter
Mud_Crazy
does the 242 have a speedo input? i plan on eventually changing the axles out
post #4 of 26 Old 12-07-2010, 11:29 PM Thread Starter
Mud_Crazy
also what would be a better swap? if going to be swapping axles down the road?
post #5 of 26 Old 12-08-2010, 12:28 AM
narnwv
narnwv's Avatar
the WJ gets its speed from the ABS tone rings on the axle shafts, not the transfer case. which makes axle swaps way more complicated.
Older 242s (from ZJs) have the speedo gear, but I don't believe you can use that type of speedo sensor with a WJ.
~Aaron
narnwv is offline
post #6 of 26 Old 12-08-2010, 01:04 AM
duranged
i have a 231HD. it has the speedo output but i haven't looked at hooking it up yet. i'm pretty sure it can be done (mallcrawlin has some posts on this). won't know for sure until i do it.
the main reasons i went with the 231 were the wide chain kit and SYE. i was able to lengthen my rear drive shaft by several inches
there are some SYE for the 242 but i've only seen hack-n-tap.
some people really like the full time 4wd for ice/snow but i don't have a use for that in SoCal.
2001 WJ Limited; 4.7L; 4.5" RK LA; 305:65:17 ProComp Xtreme AT; 231 HD w/ SS SYE; KOR sliders; ARB front w/Warn and in-cab controls; Custom4x4Fab rear; Dual Battery via 12voltguy.
duranged is offline
post #7 of 26 Old 12-08-2010, 01:28 AM
Bama_WJ
Bama_WJ's Avatar
I want to put a 231 in mine just because they seem to work so much better than the 242. Maybe I just have bad luck with 242s. Much better aftermarket for the 231 as well.
I'll agree with you on that. 4FT is a boss in the snow.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #8 of 26 Old 12-08-2010, 02:34 AM Thread Starter
Mud_Crazy
yeah the wide chain is what im intrested in. from what i have read they are better then the 242. just wanna here some input. as far as hooking up the speedo, from what i have read its just hooking up one wire to a 5v power sorce and the other to the wire (white and orange) going into the pcm i belive. as for speedo i know about the tone rings in the rear. that is why im looking into hooking up into the trasfer case for speedo.
Duranged how was installing the 231? what extra stuff did you need?
also will a 231 hold up with A V8?
post #9 of 26 Old 12-08-2010, 10:04 AM
grin
I'll be swapping in a 231 to my rig before the holiday, and yes, you can use the VSS from the t-case for a speedo signal if you're swapping axles (I'm swapping in some JK axles at the same time). I haven't picked up a wider chain/sprocket set yet, but did pick up a 6-gear planetary to swap in while I'm changing input gears to try and get a little more beef for the WJ's V8 power.
linky
grin is offline
post #10 of 26 Old 12-08-2010, 11:01 AM
duranged
The only things I had to do were 1) make sure I had the right input shaft length (2 7/8” IIRC) and 2) change the yoke on the t-case for the front DS. It bolted right up without any issues. The shift lever on the 247 is much longer than the 231 so you will also need to relocate the shift cable on one of the brackets. Not a big deal because the bracket already has a mounting point for it. I’m still running the stock front DS but obviously had to get one made for the rear because of the SYE.
The 231HD should be fine behind a V8…that’s what I had in my 5.9L Durango…hmm…you might be able to use one of those
Originally Posted by grin View Post
...you can use the VSS from the t-case for a speedo signal if you're swapping axles (I'm swapping in some JK axles at the same time).
I thought the JK axles had the tone rings
duranged is offline
post #11 of 26 Old 12-08-2010, 11:12 AM
grin
They do, but with a different number of splines than the WJ -- easier to take the signal from the t-case and adjust the gear as necessary than to try and manipulate the signal from the tone rings...
grin is offline
post #12 of 26 Old 12-08-2010, 01:49 PM Thread Starter
Mud_Crazy
sweet instal seems prety straight forward. that link helps out explaining things. so now to find a NP231HD w/ SYE. haha. might be a bit hard. but well see.
post #13 of 26 Old 12-08-2010, 01:57 PM
grin
you can make your own HD 231 -- use a regular 231J, pick up a 241 planetary gearset (6 gears v. the normal 3), pull the chain and sprockets from a Chevy 231, and a 231D (Dodge) front output shaft. walla, HD231!
grin is offline
post #14 of 26 Old 12-08-2010, 02:08 PM
sandfreestyle
or you could buy a brand new one from JB Conversions already to install. Little more expensive but no need tosource out every single part and put it together.
04 WJ V8 HO, 545rfe w/ shift kit, NP231HD w/ SS SYE, TW drive shafts, 4" RCX, 255/75/17 moabs, 55w HID projectors, Cherry Bomb Vortex muffler, Superchips, bored TB, HD Tie rod and Drag Link, IRO Steering Equalizer, Dual steering stabalizers, Homemade Sliders, 4 Hella FF75 55w HID Light bar...
“The corpse’s crimson bitter tears flow and mingle through the endless sand feeding the chaos in me and making me stronger”
sandfreestyle is offline
post #15 of 26 Old 12-08-2010, 02:10 PM
grin
Originally Posted by sandfreestyle View Post
or you could buy a brand new one from JB Conversions already to install. LOT more expensive but no need to source out every single part and put it together.
fixed!
grin is offline
2000 WJ 247 to XJ 242 Transfer case swap monc440 WJ Grand Cherokee Forum 8 05-03-2011 01:09 PM
WJ transfer case sticking johnnybwj WJ Grand Cherokee Forum 0 10-09-2010 08:32 AM
4.0 ltr I6 NV247 to NV242 / NP242 transfer case swap andrewsian WJ Grand Cherokee Forum 9 07-27-2010 10:28 AM
Transfer Case jeepkid60 WJ Grand Cherokee Forum 2 07-06-2010 10:54 AM
Transfer Case SWagner2806 WJ Grand Cherokee Forum 1 05-19-2010 07:24 PM
