2004 wj starter issues - JeepForum.com
post #1 of 13 Old 09-20-2017, 06:08 PM Thread Starter
Spotthejeep
Have 2004 wj 4.0. It fired up this morning but when I turned it off it would not start again. Gives a single click when I turn the key. Thought the starter was shot so I put a new one in without checking the old starter. Same problem so I tested the old starter and its fine. Cleaned up all the grounds and still clicks. Checked fuses and they're good. Ran a ground directly from the battery to the body of the starter and still nothing. Swapped relays and still nothing. What am I missing???
Spotthejeep is offline
post #2 of 13 Old 09-20-2017, 06:30 PM
xcaliber81
Dead battery?
xcaliber81 is offline
post #3 of 13 Old 09-20-2017, 06:31 PM Thread Starter
Spotthejeep
Battery is good, cables are clean. Got full power to everything.
Sent from my iPhone using Tapatalk
post #4 of 13 Old 09-21-2017, 05:54 AM
tsteb112
tsteb112's Avatar
2003 WJ
It's probably your connection. I had the same issue. Get some new terminals and see if that helps
2003 Grand Cherokee Overland: 4" Lift, 255/75/17 tires, Jk 10A Hard Rock Wheels
tsteb112 is offline
post #5 of 13 Old 09-21-2017, 11:22 AM Thread Starter
Spotthejeep
Cleaned all connections and nothing changed.
post #6 of 13 Old 09-21-2017, 11:23 AM
tsteb112
tsteb112's Avatar
2003 WJ
Do you have stock terminals?
tsteb112 is offline
post #7 of 13 Old 09-21-2017, 11:24 AM Thread Starter
Spotthejeep
No. Had to change them out in spring.
post #8 of 13 Old 09-21-2017, 11:35 AM
tsteb112
tsteb112's Avatar
2003 WJ
Do you have the clamp style?
tsteb112 is offline
post #9 of 13 Old 09-21-2017, 11:36 AM Thread Starter
Spotthejeep
Yes
post #10 of 13 Old 09-21-2017, 05:18 PM Thread Starter
Spotthejeep
I found the culprit! It wasn't a ground fault but the main power cable off the battery. I had to splice a longer cable onto positive and negative and thought the solder took. I was wrong!
After resoldering it, the jeep fires right up.
Thanks for everyone's help just the same.
post #11 of 13 Old 09-21-2017, 06:45 PM
blueseasons1
Sometimes a voltmeter is a better tool than a keyboard.
blueseasons1 is offline
post #12 of 13 Old 09-21-2017, 06:54 PM Thread Starter
Spotthejeep
Trouble with that is the voltmeter said there was plenty of juice everywhere even at the starter. What clued me in was after tugging on cables, the starter clicked and the dash went dead. That was a dead giveaway then.
post #13 of 13 Old 09-21-2017, 07:09 PM
tsteb112
tsteb112's Avatar
2003 WJ
Glad you found it. I figured it was the power wire as I just had the same happen with mine
tsteb112 is offline
