2004 WJ relocating evap canister and associated parts - Page 2 - JeepForum.com
post #16 of 28 Old 08-07-2013, 10:27 AM
elcorvino
2003 WJ
Also, is it common for these to go bad after quite a few (200K) miles?
elcorvino is offline
post #17 of 28 Old 08-07-2013, 01:22 PM Thread Starter
silentbob21
Common... I dunno, common enough for myself to have read about it haha. Now that I have a new pump my old pump was not near as "tight" so I would say yea, with heat and weathering springing a leak or all together shutting down seems very logical
2004 WJ SE 4.0L I6, NV242, IRO 6.5 LAs D44a Spartan locked, 4.88s, BFG KM2s 35/12.5/15
silentbob21 is offline
post #18 of 28 Old 08-07-2013, 07:15 PM
ultimo
Silentbob...can I ask how you unclipped the old hoses that was running along the sides of the fuel tank? They seem to be secured with clips. I cant reach in...so my old hoses are still hanging there LOL
Build Thread-- http://www.jeepforum.com/forum/f197/ultimos-build-1477712/
ultimo is offline
post #19 of 28 Old 08-07-2013, 11:59 PM Thread Starter
silentbob21
I believe they had some zip ties on them... I just cut and pulled them all out, was pretty easy. Helps having the jeep lifted 6.5"s haha makes for lots of room!
post #20 of 28 Old 08-08-2013, 04:37 AM
elcorvino
2003 WJ
Hmmmm... So if all the lines are up to par... It would be pretty safe to say its time to replace the canister?
post #21 of 28 Old 08-08-2013, 10:30 AM Thread Starter
silentbob21
There are several components that can fail other than the rubber hoses. LDP failing for P0455 is pretty common from what I gather, but it could also be the vent valve or the purge solenoid up front. I have read about a possible canister leak as well...
I didn't want to keep throwing parts at it so I had the smoke test performed once I knew all my rubber lines were not leaking. Also need to check the little elbows up front on the intake manifold. Mine have cracked several times I'm guessing from the heat
post #22 of 28 Old 08-08-2013, 04:37 PM
kc2mrg
subscribed .. need to do this on my wj before the CEL bulb burns out lol
2004 Grand Cherokee Laredo 4.0
Rusty's 2.5" coil/shock lift
265/70/16 General Grabber AT2's
Superchips 3875 Flashpaq
Flowmaster exhaust
West Virginia Jeep Club member
JEEPINWV.COM
kc2mrg is offline
post #23 of 28 Old 08-08-2013, 08:05 PM
ultimo
The last time my ABS bulb came on I ripped it out. Problem solved. LOL
ultimo is offline
post #24 of 28 Old 08-09-2013, 02:21 PM Thread Starter
silentbob21
Haha I did the same for my check engine a couple years ago, but CA smog won't let that fly anymore haha
post #25 of 28 Old 10-10-2013, 10:41 PM Thread Starter
silentbob21
I never updated this thread... but after replacing the LDP I have no more check engine light
The Jeep passed Cali smog no problems, now if I can figure out how to get around swapping my exhaust out and still passing haha.
post #26 of 28 Old 10-11-2013, 08:56 PM
kodiakwj
2003 WJ
That's easy you put in a flange and bolt it up, then at smog time you replace with the factory exhaust. Ask me how I know?!?!?!?!
kodiakwj is offline
post #27 of 28 Old 01-25-2017, 11:07 AM
gvelis
2002 XJ Cherokee
I have just got the same two codes on my 2002 WJ. Lots of great info here, but I was wondering if anyone has tried using a homemade smoke machine to find the leaks? They seem pretty simple on youtube
gvelis is offline
post #28 of 28 Old 06-15-2017, 10:34 AM
sm1893
great write up. im going to try this if changing the purge doesnt work
sm1893 is offline
