2004 WJ - rear wiper not sold in local stores - JeepForum.com
post #1 of 17 Old 10-19-2011, 06:00 PM Thread Starter
ry1820
I need to replace the rear wiper blade on my 04 wj.
Napa and Advanced said they do not stock that blade. What size and type of blade do I need?!?!?!
05 GC Limited - 4.7 Quadra-Trac II ~127,000 miles
12 GC Limited - 5.7 V8 Quadra-Drive II ~11,000 miles
99 GC Limited - 4.7 V8 - Quadra Drive (sold; 110,000 miles)
02 GC Laredo - I6 - Selec Trac (sold; 123,000 miles)
04 GC Limited - 4.7 V8 - Quadra Drive (sold; 132,000 miles)
07 GC Limited - 4.7 V8 - Quadra-Trac II (sold; 78,000 miles)
(OlllllllO)
ry1820 is offline
post #2 of 17 Old 10-19-2011, 06:05 PM
Gran_Paradiso
2015 Summit
Gran_Paradiso's Avatar
2015 WK
Have a look here:
NOTE: All Grand Cherokee WJ models have two 12.20 inch windshield wiper blades with non-replaceable rubber elements (squeegees). The wiper blades cannot be adjusted or repaired. If faulty, worn, or damaged the entire wiper blade unit must be replaced.
http://www.wjjeeps.com/wipers.htm#RSYSTEM
Gran_Paradiso is offline
post #3 of 17 Old 10-19-2011, 06:08 PM Thread Starter
ry1820
That is what i am looking for...the entire wiper blade not just the rubber part.
Napa sold me an "Exact Fit 60-014-1" 14 inch wiper blade, which went on but did not lock in place. It is my understanding that the smaller hook on the rear wiper of this year does not accommodate most wipers. And most auto parts stores do not stock a replacement for it...
(OlllllllO)
ry1820 is offline
post #4 of 17 Old 10-19-2011, 06:22 PM
Gran_Paradiso
2015 Summit
2015 WK
Team Grand Cherokee sells all the parts
Team Grand Cherokee
post #5 of 17 Old 10-19-2011, 06:29 PM Thread Starter
ry1820
Thank you!!
(OlllllllO)
ry1820 is offline
post #6 of 17 Old 10-19-2011, 07:11 PM
LIMITEDwoLIMITS
2003 WJ
I got a 16 inch blade from advanced and I pulled the caps off the end of the blade, and trim it up and had to bend it so it would fit o n the back glass hatch properly.
03 WJ 4.7 4X4 SWAPPED IRO 4" synergyballjoints,bilstein5100,Addco rearsway,JKS discos
LIMITEDwoLIMITS is offline
post #7 of 17 Old 10-19-2011, 09:48 PM
Fireball027
I bought mine at the dealer... I think it was $11.00
No one else around here stocked it.
Fireball027 is offline
post #8 of 17 Old 10-20-2011, 10:52 AM
AngryScientist
with a little creative prying, i managed to replace just the rubber element in mine with a universal replacement after not being able to find a full replacement at the parts store. works fine now.
AngryScientist is offline
post #9 of 17 Old 10-20-2011, 11:26 AM
georged
After reading about the availability of replacement blades I tried to take mine off. I took the cap and bolt off, but the blade arm will not pull off. After the bolt is removed I find a flat washer on the of the arm. Is there something I am missing?
georged is offline
post #10 of 17 Old 12-17-2012, 01:24 AM
E-Dub
Resurrecting an old thread to avoid a duplicate post...
I need to replace my rear wiper blade and I would like to get something quality. Does any company make an aftermarket blade to replace the OEM rear wiper?
2002 Jeep Grand Cherokee Overland Graphite Metallic
E-Dub is offline
post #11 of 17 Old 12-17-2012, 05:05 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
I am pretty sure I got my replacements at Meijer or Wal Mart. A 12" blade works.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #12 of 17 Old 12-17-2012, 06:20 AM
ssands85
Ran into this with my sisters 04.... the local dealership had em in stock for $7.00.
ssands85 is offline
post #13 of 17 Old 12-17-2012, 06:54 AM
alfaitalia
When wanted one there was about half a million of them on Ebay!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #14 of 17 Old 12-17-2012, 10:01 AM
mycreativename
The RainX summer blade (front) that is 12/13 inches also works. It has the correct clip to hold it on where-as the others don't.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #15 of 17 Old 12-17-2012, 10:21 AM
Cirruslydakota
Bought mine at the dealer as well. Heres a tip for the future. Due to its design a standard blade wont fit. When your old one wears out snap the plastic piece out that locks into the arm and just put it on the new blade.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
rear wiper joesluggo WJ Grand Cherokee Forum 2 10-02-2011 12:01 AM
rear wiper problem 4x4Jeep WJ Grand Cherokee Forum 3 05-19-2011 01:45 AM
Rear wiper arm fitment str8shot WJ Grand Cherokee Forum 3 12-27-2010 08:17 AM
rear wiper esoxhntr WJ Grand Cherokee Forum 2 11-23-2010 06:30 AM
Rear Wiper woodduck17 WJ Grand Cherokee Forum 5 05-02-2010 01:35 PM
