2004 WJ Ball joint replacement needed? - JeepForum.com
post #1 of 4 Old 11-06-2013, 08:28 AM Thread Starter
n9ljx
Question 2004 WJ Ball joint replacement needed?
Special Edition
4.0L
154K miles
All stock/oem
My left front tire showed excessive wear on the outside edge. When I had it replaced I also asked for an alignment check. They report said the left front camber was -1 degree (slide bar was to the right of 'green') off. all other positions were fine. They said I would need to replace the ball joints and to get Adjustable ball joints as replacements.
Questions:
1) any recommended brands to get and/or avoid?
2) Should I follow their recommendation on getting adjustable ball joints?
3) Plan on doing both sides upper and lower, correct?
4) Still going to have to have shop do alignment, correct?
I have never done ball joints before, but I have been known to be handy with a wrench...
--scott
2004 WJ Special Edition
Still stock - but working on it....
n9ljx is offline
post #2 of 4 Old 11-06-2013, 08:51 AM
veiri86
2003 WJ
I got the XRF ball joints from eBay, because almost everybody is complaining about Moog quality in the last two years.
I got the kit of 4 front ball joints for 155 USD.
I recommend the XRF
Sent from my iPad Mini using Jeepforum.com
R.I.P ratmonkey
Build thread:
01' 4.7 Limited WJ 5" lifted, Rubicon Express 4.5" coil springs with IRO critical path setup and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), JKS HD tie rod (MOOG problem solver Ends), JKS HD drag link (Moog Probel solver Ends), 4.56 Yukon ring and pinion, Moog HD SSD107 Steering Stabilizer, IRO Front drive shaft conversion, Stillen slotted rotors all around with Stillen brake pads, IRO adjustable A-Arm, 3" all the way Kolak Exhaust with High flow Magnaflow Cat. Converter and Flowmaster Super 50 Muffler, 285/70R17 AT Kumho (33") on 17" BlackWheel rims 909B, K&N Cold air intake, Four nozzles Bosch injectors, and Flashpaq 3780.
03' 4.7 H.O WJ 3" lifted, OME HD with 0.5" Coil spacers and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), Moog Problem solver TRE's, IRO Front drive shaft conversion, IRO adjustable A-Arm, High flow magnaflow mini cats, high flow magnaflow cat, Flowmaster Super 44 muffler, 265/65R17 AT Yokohama on 17" Rays rims, and Flashpaq 3780
veiri86 is offline
post #3 of 4 Old 11-08-2013, 08:58 PM Thread Starter
n9ljx
Is that a consensus? Is it best to avoid Moog?
n9ljx is offline
post #4 of 4 Old 11-08-2013, 09:13 PM
veiri86
2003 WJ
I didn't try the moog ball joints, but when I was in your position i read the reviews on google so if you google it you can read the reviews about the lower quality of MOOG recently compared with what they used to produce. XRF are excellent so far
R.I.P ratmonkey
Build thread:
veiri86 is offline
