-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   2004 WJ Ball joint replacement needed? (http://www.jeepforum.com/forum/f310/2004-wj-ball-joint-replacement-needed-1763465/)
n9ljx 11-06-2013 08:28 AM
Special Edition
4.0L
154K miles
All stock/oem
My left front tire showed excessive wear on the outside edge. When I had it replaced I also asked for an alignment check. They report said the left front camber was -1 degree (slide bar was to the right of 'green') off. all other positions were fine. They said I would need to replace the ball joints and to get Adjustable ball joints as replacements.
Questions:
1) any recommended brands to get and/or avoid?
2) Should I follow their recommendation on getting adjustable ball joints?
3) Plan on doing both sides upper and lower, correct?
4) Still going to have to have shop do alignment, correct?
I have never done ball joints before, but I have been known to be handy with a wrench...
:thankyou:
--scott
veiri86 11-06-2013 08:51 AM
I got the XRF ball joints from eBay, because almost everybody is complaining about Moog quality in the last two years.
I got the kit of 4 front ball joints for 155 USD.
I recommend the XRF
Sent from my iPad Mini using Jeepforum.com
n9ljx 11-08-2013 08:58 PM
Is that a consensus? Is it best to avoid Moog?
veiri86 11-08-2013 09:13 PM
I didn't try the moog ball joints, but when I was in your position i read the reviews on google so if you google it you can read the reviews about the lower quality of MOOG recently compared with what they used to produce. XRF are excellent so far
The time now is 12:55 PM.
