2004 Selec-Trac Transfer Case Issues - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > 2004 Selec-Trac Transfer Case Issues
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-14-2011, 12:40 AM   #1
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
Hello all, I went for a bit of off-roading and I keep having the hardest time getting it back from part-time to 2wd. The lever will be in 2wd however it will stay in part time (light is off too) because when I am on the road it will either bind or I can hear it... It is supposed to be shift on the fly to my knowledge. And I was going 15-20 mph too.
Any ideas to why it is giving me such a hassle between 4x4 and 2x4? (It has been doing this for a while now, this was not a first time occurrence)
Thanks
Edit: It take multiple tries of slamming the lever back up to 2wd when it is rolling in neutral for it to pop out of part time
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 07-14-2011, 06:17 AM   #2
RedlegWJ
Probably lost the plastic ends/tabs off the internal shift forks. When they go, the fork doesn't have any "reach" left.
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline   Reply With Quote Quick reply to this message
Unread 07-14-2011, 07:17 AM   #3
snobrdrkid07
Mr. WJ
Where are those located?
-Michael-
For Sale:
Unread 07-14-2011, 09:26 AM   #4
narnwv
narnwv's Avatar
If I may offer a suggestion....
When shifting between any of the modes above neutral, I generally shift, then tap the throttle twice to torque everything into place. I read that on here once, and it's worked like a charm for me ever since.
Shift to 4hi-gas-gas, go.
shift to 2wd-gas-gas-go.
~Aaron
narnwv is offline   Reply With Quote Quick reply to this message
Unread 07-14-2011, 10:05 AM   #5
FrankTheDank
Mine does this too, even after a rebuild.... I shift from 4lo or pt or what ever into 2wd while slowly moving. Stop shift to neutral, reverse.. while moving slow in reverse shift the transmission to neutral and it should help it pop in, you'll feel hear and see the t case shifter settle in gear
::4.0::42RE::242::Carolina Driveline::Spartan Locked D30::Aussie locked 44A::4.56!!!::4'' IRO LA::33/12'' Retreads::4"BS wheels::IRO T case skid::2 12'' Kenwood Subs 1000 Watt Kenwood Amp::Iceland Winch Bumper::Smittybilt XRC8::
STOCK 97 ZJ LAREDO-Daily Driver
I don't need to lie...that way I never have to remember what I said
FrankTheDank is offline   Reply With Quote Quick reply to this message
Unread 07-14-2011, 10:18 AM   #6
tjlmbklr
I have just swapped my 247 (Quadra-Trac) to a 242 (Selec-Trac) and I noticed that too. When I had it in 4Full/Part then switch back to 2HI I can tell it's still in 4WD since when I make a U-turn the wheels hop. But usually I just either drive a bit more or go a few feet in reverse but after I go back into 4WD then slam it back up to 2WD.
Hope this helps!
Bone Stock 2002 Grand Cherokee Limited
4.7L HO, Changed Stock NV247 Quadra-Drive T-case to a 242 Selec-Trac Shifter and all.
Upgraded my rims to 5 Spoke Rogue from '11 Grand Cherokee
tjlmbklr is offline   Reply With Quote Quick reply to this message
Unread 07-14-2011, 10:48 AM   #7
gqmdl0617
Any idea on the maitnance of the TC? Last time the fluid was changed?
[FONT="Tahoma"][COLOR="White"]White 2000 Grand Cherokee Laredo: 2" Fat Bobs BDS Springs with Bilstein 5100's, Addco sway bar, Black on Black heated leather, full limited wood grain, RB1, Mopar Ipod kit, 1000w of Kicker bass, 500w of lighting, Gen III projectors/5000K HIDs, Smoked full LED tails, 100w Whelen PA/Electric Air Horn with speaker mounted behind grill, Interior LED upgrade, 120v AC in the front and the back, Midland CB, PR-106 digital trunking scanner, yada yada yada. Just another WJ[/COLOR] [/FONT]
gqmdl0617 is offline   Reply With Quote Quick reply to this message
Unread 07-14-2011, 12:08 PM   #8
KayCeeJeep
My old one would do the same, just like mentioned above "popping" the gas or dropping it into reverse and backing up a little would usually flip it back into 2wd.
KayCeeJeep is offline   Reply With Quote Quick reply to this message
Unread 07-14-2011, 02:17 PM   #9
snobrdrkid07
Mr. WJ
Seems like most are having that issue or something like it.
I do not know off hand when the last t-case service was. I think there was a fluid change at 50k and now there is like 95k miles. I will have to x2 check my records.
-Michael-
For Sale:
Unread 07-14-2011, 03:48 PM   #10
Sohcvtec1995
mine use to do that, changed the fluid which was completely black, and it was good to go.
Sohcvtec1995 is offline   Reply With Quote Quick reply to this message
Unread 07-14-2011, 05:22 PM   #11
snobrdrkid07
Mr. WJ
Oh wow. How often is it supposed to be changed?
-Michael-
For Sale:
Unread 07-14-2011, 05:39 PM   #12
narnwv
narnwv's Avatar
I believe every 30k
Sent from my Atari 2600
~Aaron
Unread 07-14-2011, 05:55 PM   #13
snobrdrkid07
Mr. WJ
Originally Posted by narnwv
I believe every 30k
Oh............ crap. I need to really look at my records when I get home
-Michael-
For Sale:
Unread 07-14-2011, 06:07 PM   #14
hxcjohnny
My dad's 242 did the same thing in his jeep. His did it all consistently the entire time he had it. All the way back to when it was a baby, all the way up to when he sold it with 187k miles. I normally would just stop completely, shift to neutral, then back to 2wd. Sometimes I would have to shift into 2wd moderately hard. I think the linkage probably just needs to be adjusted a little or something simple like that. There's nothing wrong with the case.
02 WJ Overland
hxcjohnny is offline   Reply With Quote Quick reply to this message
Unread 07-14-2011, 06:49 PM   #15
snobrdrkid07
Mr. WJ
Going to go with a fluid change and see how that works. Then go from there and then look at adjusting
-Michael-
For Sale:
