2004 JGC Grinding when turning left - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > 2004 JGC Grinding when turning left
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 05-16-2011, 10:32 PM   #1
lfreitas
I have a 2004 Grand Cherokee Limited edition, and when I turn left, it grinds as if the wheels are rubbing on something. I have the same size wheels that were on the jeep when I bought it brand new in 2004 so I don’t think the tires are rubbing. Does anyone have a suggestion to what the problem might be? Thanks!
lfreitas is offline   Reply With Quote
Unread 05-16-2011, 11:35 PM   #2
Biggie862005
You should probably post more info about your jeep to make it easier to trouble shoot. Im going to assume that your jeep is a quadra-drive jeep. If so it is more then likely the differentials groaning. Change the fluid in both diffs with 75w-140 synthetic gear oil, and the dealer only friction modifier. While you are at it, may as well change the t-case oil with the dealer only 247 transfer case lubricant. All this is assuming you have a quadra drive jeep, if not then it is likely something else.
Biggie862005 is offline   Reply With Quote
Unread 05-17-2011, 06:17 AM   #3
KJINTF
2002 GC Overland - stock tires - no lift - 65K miles
I changed the front diff oil and added FM also changed the transfer case fluid all with the proper MOPAR stuff
After 300 miles or so it still groans as if the tire is rubbing once in a while on very hard left turns
Changing the fluids did reduce the noise but has not yet totally eliminated it
Retired and loving life
Current Jeeps '02 Overland & '03 Rubicon
Factory PCI Bus DRBIII diagnostic tool
KJINTF is offline   Reply With Quote
Unread 05-17-2011, 06:55 AM   #4
CanadianZed-J
Check out the axle CV joints too. If there are any tears in the boot the CV will lose its grease and will be on its way out, if it isn't already pooched.
Wheel bearings are also easy to check. Lift the front wheel a couple inches off the ground, grab the tire at 12 & 6 and rock it real hard. There shouldn't be any play.
CZJ.
So I installed the flux capacitor but the Jeep just won't do 88 mph.
-'99 WJ Limited, 4.7, Patriot Blue, 2" BB, 31" Mall-Terrains, Pavement Princess
-'97 TJ, Stone White, 4" Superlift, 33" SSRs, lunchboxed rear, 12K Titan winch, and 2.5 litres of exhillirating performance.
CanadianZed-J is offline   Reply With Quote
Unread 05-17-2011, 08:41 AM   #5
Thomahawk
JEEP ADDICTED
Thomahawk's Avatar
Quadradrive???
Change out both front and rear diff fluid with 75w-140 syntetic diff fluid add 4oz friction modifier in each diff.
Drain and refill transfer case fluid and use nv-247 fluid only for this.
This did My grouning noise when doing tight turns Go away.
But first you have to know If you have a Quadradrive or not, These Are fluids for Quadradrive ONLY.
2000 Grand Cherokee Limited ¤ 4.7 Low output V8 ¤ 545RFE ¤ Quadradrive ¤ Shale Green Metallic ¤ Agate/Carbon interior ¤ Viper 5704 alarm/remote start ¤ Alpine HU ¤ Rockford Fosgate P500-4 +P500-1bd ¤ 4X Infinity Kappa 60.9CS +1X 100.9W ¤ Rugged Ridge floor mats ¤ LED interior light ¤ Tinted windows ¤ Grill mesh mod ¤ Spyder halo headlights ¤ Spyder halo foglights ¤ 6" Hella`s 500 Black magic Lights ¤ Debadged ¤ Rear Wiper Delete ¤ Spyder LED taillights ¤ Smoked LED third brakelight ¤ LED licence plate light ¤ Saguaro 3/4in recovery shackles ¤ 3" Kolak exhaust Magnaflow cat Flowmaster 70 muffler ¤ Superchip ¤ TM snip mod ¤ 2" BDS springs ¤ Bilstein 5100 shocks ¤ Addco swaybars ¤ JKS trackbar ¤ JKS front discos ¤ IRO rear ext endlinks ¤ Moog super trial boss SS ¤ BTF Cryptonite diffcovers ¤ Stillen Rotors/Black matrix pads ¤ Pro Comp 17`s Helldorado Machined polished w/General Grabber AT2 255/70/17 ¤ JK Sahara 18`s w/Nokian Hakkapelitta R SUV 255/60/18 ¤ Urban Assault Vehicle
We dont care how they do it in Japan!
Buildthread ¤ http://www.jeepforum.com/forum/f197/...orway-1193503/ ¤
Thomahawk is offline   Reply With Quote
Unread 05-18-2011, 07:01 AM   #6
KJINTF
Not sure about the OP but mine is a Quadra Drive which was stock in the 2002 Overland
Wheel bearings are in good shape and no punchures or tears in the CV boots they look almost new
Changing the fluid did vastly reduce the noise but still every once in a while the noise returns
Unread 05-18-2011, 07:06 AM   #7
Thomahawk
JEEP ADDICTED
Thomahawk's Avatar
Do you use dealer diff fluid or diff fluid and add fm?
Try add a litle more fm.
Unread 05-18-2011, 09:20 AM   #8
lfreitas
My Jeep is a 2004 Jeep Grand Cherokee Overland 4WD....I do not have Quadradrive. Sorry guys I'm doing the best I can do here (female writing). I have my original sticker, it does say Quadra-TracII on Demand 4WD System. I have no clue if thats Quadradrive. I'm just trying to figure this out. The guys that do work on my car have added more power steering fluid but that did nothing. They can't find whats wrong otherwise. I've posted other messages about small problems with my Jeep and everyone here has been great, those problems were fixed with posted messages. Thanks again!
Unread 05-18-2011, 09:40 AM   #9
Thomahawk
JEEP ADDICTED
Thomahawk's Avatar
Ok then you do not have the Quadradrive. You have the quadratrac version. These Are different 4x4 systems. The Quadradrive act like this when its not used correct fluid.
Unread 05-18-2011, 02:05 PM   #10
shepd
Probably not your problem, but I had the exact same problem, it only appeared when turning left. The plastic covering protecting wheel well was loose and the tire was rubbing on it (it actually got stuck there). I cut the loose plastic off, since much of it had worn away from this abuse anyways, and the problem is gone. I figure a little extra dirt hitting the bumper isn't going to matter much.
shepd is offline   Reply With Quote
Unread 05-19-2011, 07:10 AM   #11
KJINTF
Not sure if you have seen this Jeep Service Bulletin - might be the issue with the left turn noise
Thanks - I will try a bit more FM, yes all fluids were the expensive and proper MOPAR stuff. I added as the manul stated 2.5oz of FM when I changed the fluids will add about 1 more oz
