2004 jeep laredo 4.0.. Need help please!!! - JeepForum.com
post #1 of 5 Old 05-07-2012, 01:05 PM Thread Starter
David_Hutch
Hi my name is David im a certified Asian motorcycle tech and know nothing about 4 wheels lol. I just recently purchased a 2004 jeep laredo 4.0 with 90,000 miles on it and i need help. I think i have either a fuel issue or a clogged cat. Its throwing a code P0031 which is Oxygen (A/F) Sensor Heater Control Circuit Low (Bank 1 Sensor 1) but i dont think that could be whats causeing my problem. whats happening is when i hit the throttle it will rev up to 3000rpm and start to break up. Sometime it will rev higher but still cuts in and out. which makes for a really rough ride cause the rpm and speed is right were the tranmission wants to shift so it jumps up and down through gears cause its breaking up. If i ease on the throttle it rides and shifts very smooth. stomp on it and the rpm goes up very slow and it start cutting out once it gets up in rpm.
PLEASE SOMEONE TELL ME WHATS GOING ON.
Thanks
David_Hutch is offline
post #2 of 5 Old 05-07-2012, 01:12 PM
adolphhipster
did you check your tranny fluid? and welcome
adolphhipster is offline
post #3 of 5 Old 05-07-2012, 01:27 PM Thread Starter
David_Hutch
I have checked the trans fluid and its good. It does it even if your in park or neutral reving it up.
post #4 of 5 Old 05-07-2012, 04:53 PM
jeep_dude
Could be a couple of things. I had a problem once with erratic idle - it would rev high and stay there, or suddenly drop to normal. I originally thought it was the TPS (throttle position sensor), but I wound up getting the crank sensor replaced when it broke down one day and ever since its been fine.
jeep_dude is offline
post #5 of 5 Old 05-07-2012, 08:09 PM Thread Starter
David_Hutch
Ok I haven't checked the crank sensor or tps yet. Is there a a/c volt reading the crank sensor should put out?
Transmission issues 2004 GC Laredo Samiam89 WJ Grand Cherokee Forum 2 10-12-2011 06:31 AM
2004 Laredo No Power to Driver Door Flyusaf2002 WJ Grand Cherokee Forum 2 05-05-2011 03:11 PM
Looking at a 2004 - Quadra Drive Limited or Selectrac Laredo? canuckJGC WJ Grand Cherokee Forum 46 04-08-2010 12:57 PM
2004 Grand Cherokee Laredo w/ 29k miles.....Any ISSUES w/ this year? KhakiSport03 WJ Grand Cherokee Forum 11 07-28-2007 08:05 PM
2004 GC Laredo -- best tires? ggrumpsy WJ Grand Cherokee Forum 4 03-14-2004 06:45 AM
