2004 Jeep Grand Cherokee won't start :( - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > 2004 Jeep Grand Cherokee won't start :(
6th annual beat your wife to the credit cards sale!!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectRugged Ridge Products Promo Calendar - Promo Code 2016CAL
Unread 01-23-2011, 07:27 PM   #1
Hi everyone,
We have a 2004 Jeep Grand Cherokee that is setting in our driveway right now because we can not get it to start. We have changed the fuel pump, fuel filter, all the filters in the tank, throttle position sensor, crankshaft position sensor. We have checked the battery, everything is fine.
My dad said that he can't get gas from the main line to the injectors. We can't tell if the fuel pump is getting any power.
This summer it started hesitating while you were driving. Not every time that you drove it, probably every 30 to 40 miles and then it would run fine. It would also blow black smoke. Took it to the repair shop couldn't find anything wrong with it. So we brought it home and changed the spark plugs. The car ran like a dream for a couple more months.
A week before Christmas it started stalling while we were driving it, blowing the black smoke again, and jumping like it was gas starved. We took it to autozone and they hooked it up to the diagnostic. It showed that it was the throttle position sensor. We bought that and changed it. It ran great for a day or so. Then it started the same thing all over again. We took it back to autozone and they still said it was the throttle position sensor. So we took it back off and took it back to autozone and they gave us another one. Installed the new one, ran fine. My dad took it out for a test drive, he got about 9 miles from the house and it started it again. He got it halfway home and it completely stopped. He couldn't get it started again, had to have it towed. That is when we started changing everything that we could think of.
Please help!!!! We have no idea what else to try. It is a 2004 Jeep Grand Cherokee with a 4.0L engine.
jennybugz is offline   Reply With Quote Quick reply to this message
Unread 01-24-2011, 10:24 AM   #2
Double E
2000 Laredo V8
Double E's Avatar
This sounds like need for an OEM TPS first, then (if still happening) you might do a search for the PCM connector problem that's been described in previous threads.
The PCM issue has to do with poor or marginally stable connections at the plug at the PCM and some internal contacts that just need to be freshened and repaired.
Disclaimer: My response only comes from being on this forum for a long time, not personal experience.
2000 Laredo 4.7L Selec-Trac. 177K miles, Leather, 245 tires, tow package, crappy CD changer, full size spare, roof cross-rails & sunroof.
Changes & fixes: Rear Addco sway bar & greasble bushings, upgraded headlights, upgraded tail lights, new hood struts (replaced 2X), new rear hatchglass struts, new radiator (replaced 3X), new oil pressure sending unit (replaced 4X), 2 new speed sensors, 2 new door lock actuators, new ignition key cylinder, chrome front tow hooks, Mobil 1 Synthetic 5/30, Purolator Pure One oil filter, EBC slotted & dimpled rotors, EBC Greenstuff pads, new front shocks (replaced 3X), new rear shocks (replaced 2X), new IRO steering stabilizer, new timing chain cover, new water pump, thermostat, new thermostat housing, new high pressure power steering hose, Michelin-X radials, new sunroof assembly, new single-piece lug nuts, new exhaust manifold studs & gasket on driver's side, new Durango alternator. Jeepforum.com sticker, Visit cobaltboatsforum.com when you can!
Double E is offline   Reply With Quote Quick reply to this message
Unread 10-16-2012, 09:33 PM   #3
2004 CJ2A
Get an OEM Fuel filter the Autozone fuel filter does not have the fuel regulator. Try getting the dealer fuel pump and install it.
gerardrford is offline   Reply With Quote Quick reply to this message
