2004 jeep grand cherokee stuck in first gear - JeepForum.com
post #1 of 6 Old 09-15-2012, 03:56 PM Thread Starter
skts36
My jeep won't shift out of first gear, error code p0720. I replaced the output shaft speed sensor and the vehicle drove perfectly although check engine popped back on. I drove around for a bit and all was well. I parked the vehicle and restarted it and have same issue. The fact that the transmission is capable of shifting properly tells me that the transmission is physically fine and my issue must be sensor/computer related. Also 6mo ago I replaced the governor solenoid and oil pressure sensor inside the trans because of shifting issues. That was an easy fix. Basically, I have no sensors left to replace... any ideas suggestions would be greatly appreciated.
skts36 is offline
post #2 of 6 Old 09-15-2012, 06:49 PM
2003wj
It could be the Governor Pressure Sensor and Solenoid here is a link to a great write up on how to fix.
http://www.jeepforum.com/forum/f310/...te-up-1182260/
2003wj is offline
post #3 of 6 Old 09-15-2012, 08:12 PM
jimwww
jimwww's Avatar
I do know that on the chrysler minivans if the battery is just a bit low the trannys will not shift (stay in first gear). I am unaware if the jeeps do the same thing - but it maybe a possibility.
1999 Jeep GC Laredo ( WJ ) White 6cyl
jimwww is offline
post #4 of 6 Old 09-16-2012, 01:28 PM Thread Starter
skts36
2004 jeep
Battery is one month old. The pressure sensor and solenoid changed 6mo ago....
skts36 is offline
post #5 of 6 Old 09-16-2012, 01:33 PM Thread Starter
skts36
I believe the transmission is a 42re. There is a sensor further up the transmission, is this the input shaft speed sensor? It is on driver side top of trans by the fluid pan.
skts36 is offline
post #6 of 6 Old 09-15-2016, 01:16 PM
brittont
We drive a 2003 Jeep Grand Cherokee. With no prior shifting problems experienced, transmission will not shift ou of first gear. Any suggestions for a fix???
brittont is offline
2004 Jeep Grand Cherokee won't start :( jennybugz WJ Grand Cherokee Forum 2 10-16-2012 09:33 PM
used jeep grand cherokee limited v8 4.7 2004 ezki82 WJ Grand Cherokee Forum 3 07-18-2012 05:32 PM
2004 jeep grand cherokee wj lift help 04jeepin WJ Grand Cherokee Forum 2 03-28-2012 05:45 AM
2004 grand cherokee won't go into gear dmb499 WJ Grand Cherokee Forum 4 07-29-2007 04:07 PM
Headlights on the 2004 Jeep Grand Cherokee boyandhisjeep WJ Grand Cherokee Forum 1 10-21-2003 02:38 PM
