2004 Grand Cherokee V8 4.7 L Water Pump - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > 2004 Grand Cherokee V8 4.7 L Water Pump
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSavvy Aluminum BumpersThe RuffStuff "I can't go to EJS" Sale!
Unread 06-30-2013, 01:31 PM   #1
Ckess22
I made a diagram as I took the the old one out to ensure that I got the bolts back in their correct spots...anyhow, as I am truly amateur at this, I am second guessing the placement of the bolts...ie which ones go where. Does anyone have a pic/diagram of which bolts go into the assembly where? Anyhow, any instruction here would be great...
thanks.
Ckess22 is offline   Reply With Quote
Unread 06-30-2013, 02:48 PM   #2
99SK04GTX
I doubt something like that is available. As you put the bolts in you should have about a half inch of thread exposed. If the bolt bottoms out you know it is too short, if you have an inch of thread exposed that bolt it too long for that location. A little trial and error and you should get it right.
99SK04GTX is offline   Reply With Quote
Unread 06-30-2013, 02:54 PM   #3
ezflip
Theme Park Dinosaur Head
ezflip's Avatar
How many threads need to be started for your water pump issues? This is what, number 3?
The numbers indicate which order they should be installed. Looks like they are all the same except for 1. For the others, it doesn't really matter which ones go where. If they are different lengths, guess and check. It will be pretty obvious if it doesn't fit.
2002 Overland - 4.7 HO, "Select-Drive", 4" RC long arms, TAG front winch bumper, 32" BFG KM's, Kolak 3" exhaust, Flowmaster 50 series
Build Thread
KCCO
ezflip is offline   Reply With Quote
Unread 07-01-2013, 12:43 AM   #4
Jer-Bear
Last time I checked, we don't get paid to answer questions on here man. If you don't like the thread, don't click on it and read it. Take it easy.
2002 Jeep Grand Cherokee 2WD 4.7L H.O. SOHC
Jer-Bear is offline   Reply With Quote
Unread 07-01-2013, 08:42 AM   #5
ezflip
ezflip's Avatar
Just like to keep the forum clean is all. It doesnt do anyone any good when the front page has 5 threads of the same question.
Build Thread
KCCO
Unread 07-01-2013, 08:55 AM   #6
USFORCES
Agreed, some of the same questions get asked almost on daily basis, Water on passenger side, Drive shaft length ect. Sometimes I go up one page and copy and paste the answer
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline   Reply With Quote
Unread 07-01-2013, 12:21 PM   #7
rdkendrick
2003 WJ
Been a lot of A/C questions, lately. Probably because of the onset of summer.
Sent from my iPad using Forum Runner
rdkendrick is offline   Reply With Quote
