2004 Grand Cherokee Pwr Window/lock Failure! - JeepForum.com
post #1 of 4 Old 07-30-2007, 11:32 AM Thread Starter
dfred1962
Hey anyhelp is appreciated:
The driver side controls stopped working for all windows/locks.
However lock on passenger side still locks all doors except drivers.
All Windows are powerless. checked all fuses under dash they are good.
Anyone have to fix the same!
dfred1962 is offline
post #2 of 4 Old 07-30-2007, 11:52 AM
merlinTec
merlinTec's Avatar
Hi
Common fault the wires brake from the door to the car. Pull the boot back can’t miss it most of the time it’s just the earth black wire
Regards,
Merlin
merlinTec is offline
post #3 of 4 Old 07-30-2007, 12:10 PM
nierace
nierace's Avatar
2003 WJ
It would be pretty unlikely all the wires would fail at once...
I would replace the fuce for the power windows/locks even if it looks good and go from there.
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #4 of 4 Old 07-30-2007, 03:19 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Not all the wires fail. Only one has to fail for this problem to occur, and that is the ground wire. All the locks and windows operate through the master control on the drivers dood by being provided a ground. If the ground wire breaks, nothing works.
Check the wires from your door into the body, pull the rubber boot back and look for any broken wires.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
Grand Cherokee power window/lock problem 737FlyGuy ZJ Grand Cherokee Forum 69 01-04-2017 04:54 PM
1996 Grand Cherokee power window and lock problem jrenegade13 ZJ Grand Cherokee Forum 2 12-31-2011 09:36 AM
Electic Window/light Gremlins 2004 Grand johnrichards ZJ Grand Cherokee Forum 1 12-22-2009 01:44 PM
Grand Cherokee Speedometer Failure goehm ZJ Grand Cherokee Forum 10 05-27-2009 09:47 AM
04 Grand Cherokee AC & Blinker Failure - HELP - Forst2Jeep ZJ Grand Cherokee Forum 2 08-27-2008 06:54 PM
