2004 GC Track Bar Removal - JeepForum.com
post #1 of 10 Old 07-06-2013, 10:38 PM Thread Starter
javsst
2012 WK
Question - trying to remove the bolt on the drivers side
for the track bar on my 04 GC. One problem. The nut faces
forward and the bolt when slid back hits the axle bumper.
It doesn't look like the bumper can be unbolted from underneath. Any ideas?
Thanks.
Steve
2012 Jeep Grand Cherokee Laredo E
javsst is offline
post #2 of 10 Old 07-06-2013, 10:40 PM
USMC_XJ
2003 WJ
The bumpstop? The 2 WJs that I have worked on required minimal trimming with a knife to have the bolt clear. It is possible to pull the stop out, but there isn't enough space to proper grasp it. Cutting is effective and pretty harmless.
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline
post #3 of 10 Old 07-06-2013, 10:45 PM Thread Starter
javsst
2012 WK
Good to know. I have an air body saw that should trim it out nicely.
Thanks!
Steve
javsst is offline
post #4 of 10 Old 07-07-2013, 03:31 AM
w33mud
2006 WK
Just done mine,lever the bump stop out with a screwdriver,I had to remove the cup it sits in aswell,with the bumpstop removed you can see the two bolts that hold the cup in place,remove the rear bolt & loosen the front & the cup will slide back enough to remove the bolt.cheers.
w33mud is offline
post #5 of 10 Old 07-07-2013, 03:23 PM
JRobes
When I removed mine I just used 2 large slotted screwdrivers as prybars and one at a time pryed them up and in between the metal cup and the rubber bump-stop. each screwdriver will stretch and pry the bumpstop out little by little.
2004 WJ Overland, 4.7HO, Quadradrive, 3" OME HD/Bilstein lift
1999 Honda Magna VF750C
JRobes is offline
post #6 of 10 Old 07-07-2013, 07:59 PM Thread Starter
javsst
2012 WK
Guys -
Thanks for the input
Question - is the bump stop replaceable once removed?
Thanks!
Steve
javsst is offline
post #7 of 10 Old 07-07-2013, 08:21 PM
JRobes
the sides of the metal cup that holds the bumpstop has two formed notches that bite into the left and right sides of the rubber bumpstop and they are just as effective after you reinstall the bumpstop.
JRobes is offline
post #8 of 10 Old 07-08-2013, 03:27 AM
ADragg
2003 WJ
Yes, it's completely replaceable. I actually had a hell of a time getting mine out the first time and I keep them lubed slightly just so I can quickly pull them out for track bar adjustments or other lift/suspension related stuff that requires it getting out of the way and I've put it on and off many times and it sits in there with grease, always easily removable, yet never falls out on it's own or anything. It's poly or something similar, it's not really going to wear out. But if it did, you could just bang the tabs in a little deeper to tighten it up, or buy replacement ones from Crown, which I never expect to have to do.
3.5" lifted '03 Limited Quadra Drive WJ - OME HD coils, Bilstein 5100 shocks, JKS track bar, IRO extended links, OME 10mm spacers, Moog SS, JK Moab wheels w/ 265/70/17 (32") Goodyear Duratracs.
ADragg is offline
post #9 of 10 Old 07-08-2013, 09:54 AM Thread Starter
javsst
2012 WK
Guys -
Thanks. I wanted to make sure I didn't need one before I started
on the job
Steve
javsst is offline
post #10 of 10 Old 07-23-2013, 10:07 AM Thread Starter
javsst
2012 WK
Just wanted to say thanks again!
I did the track bar replacement last week and by using a couple of small
pry bars, I was able to remove the bump stop without much of an issue.
Put some moly grease on the top surface of the stop and it snapped right
back in after I had everything bolted and torqued.
Steve
javsst is offline
