2004 fuse #20 keeps blowing - JeepForum.com
 3Likes
  • 1 Post By Double E
  • 1 Post By THEBAD1
post #1 of 6 Old 08-22-2017, 05:31 PM Thread Starter
esnow17
I had my turn signals to quit working but the hazards work fine. I followed the steps to resoldier the pins on the flasher relay but did not fix the issue. I looked at the fuses and 20 was blown. Put a new one in and instantly blew again. Any suggestions?
esnow17 is offline
post #2 of 6 Old 08-23-2017, 12:01 PM
Double E
Double E's Avatar
Soldering was not done right and it sounds like there was a short created?
...assuming 20 is for turn signals.
New relay or check solders again and test one to the other with a meter to see where you have connectivity between the parts soldered.
esnow17 likes this.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #3 of 6 Old 08-29-2017, 12:19 PM Thread Starter
esnow17
I replaced the flasher relay with a new one, $60, instead of trusting my soldiering job. Replaced the blown fuse as well. Turned the key to the jeep and instantly the #20 fuse blew again. New relay with the same fuse blowing. Hazards work fine. Individual indicators still not working. Any other suggestions?
esnow17 is offline
post #4 of 6 Old 08-29-2017, 03:18 PM
Double E
Double E's Avatar
Hmm...so #20 was blown (or could have been) before the initial soldering job was performed.
Tell me what #20 is labeled to control...
Been towing a trailer recently?
esnow17 likes this.
Double E is offline
post #5 of 6 Old 08-29-2017, 04:03 PM
THEBAD1
I had a problem like this. If you tow check the wire harness from you hitch plug to your tail lights...if aftermarket. I had a bad wire that was tapped into the wiring from the tail light. Fixed it, fix my problem blowing the fuse.
esnow17 likes this.
Jeep Grand Cherokee/WJ 4.7/ Laredo 2004
THEBAD1 is offline
post #6 of 6 Old 08-30-2017, 11:02 AM Thread Starter
esnow17
wjjeeps.com/fuses.htm is where I found the diagram with descriptions of each fuse. I tow my mower and that's the heaviest thing I tow with it. After rereading the descriptions, my A/C is not working either. If I can stop #20 from blowing I might have A/C again!
esnow17 is offline
