2004 4wd not working? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > 2004 4wd not working?
Save on Selected Dynomax Exhaust Systems!Rough Country Lift Kits and Parts!All Bilstein shocks & struts - Lowest Prices Ever and
Unread 02-16-2015, 01:47 PM   #1
Juggernaut_7
I have a 2004 Overland with Quadra drive and it snows which is rare here where I live and 4wd isn't working in all time position or in 4 low. Anybody wanna help diagnose what my problem could be?
Juggernaut_7 is offline   Reply With Quote Quick reply to this message
Unread 02-16-2015, 06:50 PM   #2
Tollmtn
With all 4 wheels on the ground and with the T case in high range try turning the front driveline by hand. If you can turn it then something in the front differential is broken. Even if something in the differential is broken you will feel some resistance because you are turning some of the parts in the T case when you turn the driveline.
Then if you can turn the driveline by hand in 4 high put the T case in 4 lo and try to turn the front driveline by hand, you should not be able to turn the front driveline. If the front driveline can be turned by hand in 4 lo try moving the Jeep a little just to be sure the T case actually locked into 4 lo. When you are sure it is in 4 lo if you can hand turn the front driveline you also have a T case problem.
Lately quite a few people have noticed a problem with their front differential, in several cases one of the axles had been replaced with the wrong length axle shaft. There is about a 1" difference in length between Vari-Lok axles and open differential axles.
Tollmtn is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 07:52 PM   #3
Juggernaut_7
Today I tried turning driveshaft like u said in all time position and in 4 low and I can get it to turn so what next?
Unread 02-18-2015, 07:54 PM   #4
mr312712
Since It turns In 4LO In Park It's a t-case problem most likely the chain snapped.
Don't Call An Engine A Motor.
Replace With MOPARŪ Or Have problems
04 WJ Overland 4.7 H.O. Red
mr312712 is online now   Reply With Quote Quick reply to this message
Unread 02-18-2015, 08:32 PM   #5
Juggernaut_7
I screwed that message up and just saw it. I meant to type I CANT turn it. Sry
Unread 02-18-2015, 08:40 PM   #6
mr312712
Well In that case If the front wheels have power In 4LO then the case Is fine If not then u have a problem In the front axle.
Unread 02-18-2015, 08:47 PM   #7
tymaoaretae
2003 WJ
I snapped both my cv axles at the cv joints last week and it did exactly what yours sounds like it's doing. Power was going to the front, just not to the wheels. Replaced the shafts over the weekend and now it works great again.
tymaoaretae is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 09:10 PM   #8
xxturbowesxx
I dont think the Progressive coupler in the 247 used the transfer case chain to send power anywhere. Usually when AWD goes out the 4LO will still work.
I'd be looking somewhere besides the transfer case.
xxturbowesxx is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 09:30 PM   #9
Juggernaut_7
10-4 I'll look into it more. I put a new cv driver side axle in it last year, so I dont think it's that but could be.
Unread 02-18-2015, 09:39 PM   #10
mr312712
Depends did u put a Quadra-Drive axle on or Selec-Trac and it could be the other side.
Unread 02-18-2015, 09:39 PM   #11
tymaoaretae
2003 WJ
My driver's side cv was only about 18 months old, but it snapped all the same.
Unread 02-19-2015, 01:25 AM   #12
Juggernaut_7
It was Definitely supposed to be for quadra drive because I had the part numbers looked up for them at Oreilys when I got there and they confirmed it was for my Overland model.
Unread 02-19-2015, 07:27 AM   #13
Tollmtn
I noticed that several people that bought front axles from O'Reilys ended up with the wrong length axle. However on the drivers side the axle for Q drive is 1" shorter than the axle for an open diff so I doubt that you could have gone wrong there.
I also notice that tymaoaretae had some axles snap, I had the same thing happen and have mentioned this before. My axle snapped off clean inside the rubber boot, the boot was holding the axle up in position so it looked OK. But what was happening was the the clamp on the boot was not tight enough to twist the boot and rip it so the axle was spinning in the rubber boot. It took me a while to find that one.
Unread 02-19-2015, 08:28 AM   #14
tymaoaretae
2003 WJ
Mine was similar. The boots held them in place as long as the wheels were straight, but it became pretty obvious if I turned them at all.
Unread 02-20-2015, 02:43 AM   #15
Juggernaut_7
So basically I need to check passenger side axle really well? Low fluid or in need of a change cause my problem? Was fixing to do front and rear diff, transmission and transfer case soon anyways.
