The other day I got a CEL with a P0420. I am looking at replacing the Y pipe with both cats. Did the Y pipe change from 2003 to 2004?
I found a couple OEM replacements on one of our favorite online retailers and they say *to 05/02/03.* Did they really change the design in May of 2003?
Also, many of the options state not legal for sale or use in CA... Does this just mean they arent CARB approved? Or does this mean they wont work on a vehicle with CA emissions? They still have two cats with 4 O2 bungs so I dont see why they wouldnt work.
I am not 100% sure, but if the cat does not have the cats do not have the correct info tag on them, they will fail automatically the visual inspection. Talk to kolak about it, magnaflow makes one I believe that is commiefornia legal.
Thanks, I don?t live in CA. I live in MD. We have bi-annual emissions testing but no visual inspection of the cat. They just plug into the OBD port and take a reading. Usually in and out in 2 minutes. I?m less concerned about not having a CARB approval than I am about fit and getting rid of the code.
I have the later style with two cats on the Y pipe and no main cat after the Y pipe. I?ve just seen conflicting info saying the design changed after build date 05/02/03 but I also read the change happened in late model year 2004. So I just want to make sure I order the correct one.
Thanks. I didn?t think I would need 50 state cats. See description below as to why I think it?s the cat. But I will not order a new Y pipe until we are sure. Appreciate the caution!
The Y pipe design did change around 2003. Since you have a bank 1 and 2 is the 420 for bank 1?
You could start by replacing the after cat O2 sensor on bank 1 or both banks if your sensors are old. Also look for exhaust leaks.
I punted on my 97 4Runner and put a bottle of Cataclean in and the code cleared in 120 miles and had stayed away for 4000 miles. But the 4Runner had sat for over a year with a bad engine before I bought it and swapped engines.
I replaced the drivers side upstream in May as it went bad and the code on the scanner pointed to the 1/1 sensor. It started running terrible and smelled awful! A new mopar sensor did the trick then.
I know the manifolds aren?t leaking and I would be shocked if I had a leak from the manifolds to the y pipe. The motor was rebuilt in March so the manifolds were decked and new gaskets were installed along with new bolts at the Y pipe.
I took the jeep wheeling last month and unfortunately got into a lot of mud (not by choice). Afterwards I did have some gurgling sound from the exhaust. My guess is water got in the tail pipe maybe towards the muffler. I?d be surprised it water got all the way up to the cats.
Right now the jeep smells like it?s running rich. From what I read, I sort of ruled out O2 sensors because I thought that unless there was a leak, the P0420 code will be present when both sensors are getting similar readings, indicating the cat isn?t working any longer. The cats have about 130k on them. I?m all about not spending the money on a new Y pipe but what I don?t want to do is replace the remaining 3 O2 sensors to find out it?s the drivers cat anyways.
if you have a android anything get Torque Pro and a dongle. It will do the graphing.
But if you have anywhere near 200k miles on the factory O2 sensors it's time to get new mopar or NTK sensors and start over
Also, no exhaust leaks within 4ft of a O2 sensor. (Or no exhaust leaks.) The reversion will draw fresh air in and totally screw up the O2 sensor reading.
With live data what are your LTFTs for bank 1 and 2?
The po of mine obv had a bad cat and instead of replacing the whole y he had an aftermarket welded in.
It would still throw a 0420 code.
Spaced out the rear o2 with the antifouler and boom she passed pa emissions for 3 years until I found the y pipe locally from a member of this board and swapped it out.
Does you Grand have and exhaust leak at the left manifold? It it does it will cause the o2 sensors not to read write and cause a p0420. Seen a few of these especially on the WK's . Being you not in California then CARB excempt doesn't apply to you. And the o2 sensor exstensions/ coolers do work if you have a weak cat.
Save a lot of money Do the spark plug anti fouler trick. The po of mine obv had a bad cat and instead of replacing the whole y he had an aftermarket welded in. It would still throw a 0420 code. Spaced out the rear o2 with the antifouler and boom she passed pa emissions for 3 years until I found the y pipe locally from a member of this board and swapped it out.
I forgot to mention the sensor voltages I posted earlier were at idle.
I figured out how to log LTFT?s and sensor voltages and drove around to make two logs. There are nearly 400 frames of data. I?m trying to figure out how to get it out of the scanner to a computer.
Here?s the weird thing. While I was logging, the motor hesitated twice and then the CEL turned off. No codes are stored on the PCM anymore. WTF!
Just an update...jeep started running terrible and something is rattling really loud inside the bank 1 cat. Sounds like the core is falling apart. New Y pipe it is.
Thanks, I appreciate the offer but unfortunately the Magnaflow 49494 is for 99-01 applications. I have an 04 with the updated two mini cats and no main cat setup. GL with the sale.
I just replaced a cat. They seem to either be CARB compliant and typically 50 state compliant or 49 state compliant minus CA or 48 compliant minus CA and NY.
CARB is 100% a CA thing, it actually means California Air Resources Board, which is short for we found another way to take your money. I wouldn't worry at all about it if you don't live in CA.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
