2004 4.0 I6 Jeep Grand Cherokee Camshaft, Timing Set, and Lifter Replacement - Page 3 - JeepForum.com
post #31 of 41 Old 05-01-2012, 10:19 PM
super98lsc
Glad you saved it. I cant wait to get my new solid lifter Lunati custom grind and full cnc ported 2" valved head back from 505 it should run much stronger than my last combo. Wish I didnt have to re machine the entire short block again though :-(
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #32 of 41 Old 09-07-2012, 01:06 PM
Mboelts
Raising a dead thread, thank you thank you thank you, I know I own an 04 LJ, but this walk through is just what I needed. I started with a mis fire in cylinders 1 and 6, now I have no compression in those cylinders after checking and replacing almost everything else. So this weekend I will start going through the engine and this walk through made it a lot easier to see what needs to be done to get to the bottom of my issue! Thanks again!
-"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." - Frank Sinatra
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
KCCO!
Mboelts is offline
post #33 of 41 Old 09-07-2012, 01:46 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Always glad to help! Good luck!
Edit: I just noticed you are a Chiver.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #34 of 41 Old 09-07-2012, 03:01 PM
Mboelts
Yep and I will really need to remember to KCCO on this "project"!! LOL
KCCO!
Mboelts is offline
post #35 of 41 Old 01-29-2013, 06:43 PM
Jeepeiro_fl_usa
Hi Chris nice write up so yesterday i found some pieces of rings and 2 parts of the piston on the oil pan after removed,engine was knocking like a diesel.I bought the 2000 about 2 months or so i they replaced the cylinder head 0331 the famous for cracking but is not cracked yet and i don`t know the best way is fix the engine or just get a used from another year like 96/98 and make the coil pack hardware...any help will be great,thank you.
Jeepeiro_fl_usa is offline
post #36 of 41 Old 01-30-2013, 08:29 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
I'd suggest seeing if it can be rebuilt (if you have the time for the WJ to be down). If not, look for a reman or crate engine specifically for the WJ. You will have less issues if you get the appropriate engine.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #37 of 41 Old 01-30-2013, 11:59 PM
Ripper600
2003 WJ
coolant Fun
Hey Chris, Chris here
wondering if you had used your old radiator hoses. I did and i am leaking coolant like a SOB. wondering if you ran into this too...im convincing myself its just the hoses having a werid runoff pattern (like off the AC compressor and dripping there)
Ripper600 is offline
post #38 of 41 Old 01-31-2013, 08:36 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
I did reuse my old hoses. I, too, had a leak develop shortly afterwards. I *thought* it was the water pump going out. I bought a new pump, thermostat, and fluid and went after it. Partially into the process, I realized the leak was actually coming from the tube attached to the water pump:
It wasn't tight enough. Since I was already into the project and already had everything I needed, I went ahead with replacing everything.
Moral of the story, check that tube.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #39 of 41 Old 01-31-2013, 05:11 PM
Ripper600
2003 WJ
thanks for the input
Mine seems to leak more when its cold in the morning and going short distances, Im thinking ill just replace the radiator hoses. I already replaced the water pump and thermostat with my build too....Im starting to wonder if i didnt break-in the head gasket well enough, Im getting it out on the high way tomorrow maybe the high rpm travel will help, all Iv done is short commutes around town.
post #40 of 41 Old 10-27-2015, 10:32 PM
i6zombiejeep
Thanks for the awesome thread! Definitely is helping me
i6zombiejeep is offline
post #41 of 41 Old 10-28-2015, 08:40 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
No problem!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
4.0 , head gasket , lifter , radiator , timing chain
2004 Jeep Grand Cherokee won't start :( jennybugz WJ Grand Cherokee Forum 2 10-16-2012 09:33 PM
2004 Jeep Grand Cherokee Limited blower resistor replacement erich67 WJ Grand Cherokee Forum 12 07-20-2011 11:29 AM
99 jeep grand cherokee limited timing natathome WJ Grand Cherokee Forum 3 03-20-2011 06:53 PM
2004 Jeep Grand Cherokee---Overheating after water pump replacement! Thoughts? Hundoracer WJ Grand Cherokee Forum 2 07-05-2010 04:22 PM
Headlights on the 2004 Jeep Grand Cherokee boyandhisjeep WJ Grand Cherokee Forum 1 10-21-2003 02:38 PM
