2003 WJ Voltage around 29 volts at battery.. - JeepForum.com
post #1 of 8 Old 07-22-2014, 09:30 PM Thread Starter
afearlesshunter
2003 WJ
I installed a new subwoofer amplifier in my new to me 2003 Wj with the 4.7l v8 and I noticed the amp was getting hot quickly. Tonight I checked my voltage (With the jeep running) and it read 29.2 volts.. What would cause this? is this normal?
afearlesshunter is offline
post #2 of 8 Old 07-22-2014, 09:32 PM
bessyboy
That's impossible, your whole car would fry in a second!
-2001 WJ Limited, 4.7L V8, Thrush Glasspack muffler dumped before axle(no tailpipe), Spectra CAI,
Rusty's 2" BB
bessyboy is offline
post #3 of 8 Old 07-22-2014, 09:34 PM Thread Starter
afearlesshunter
2003 WJ
I am very puzzled. I have a voltage meter installed in the inside 12v outlet that consistently reads 13.5-13.6v but on the battery terminals i get 29 something ..
post #4 of 8 Old 07-22-2014, 09:38 PM
bessyboy
What does the gauge on the dash read?
Rusty's 2" BB
bessyboy is offline
post #5 of 8 Old 07-22-2014, 09:38 PM Thread Starter
afearlesshunter
2003 WJ
Nvm im retarded . sorry guys.
post #6 of 8 Old 07-23-2014, 03:54 AM
5-90
5-90's Avatar
1988 XJ Cherokee
You have a major problem.
However, is it a major problem with your charging system (29.2VDC is FAR too high for a 12V system!) or with the meter you used to check it?
Verify it with a second DMM.
Nominal voltage for automotive systems is 12.0VDC. Typical battery voltage is 12.4-13.0VDC, typical running system voltage is slightly higher (12.8-14.0VDC.) More than 14.0VDC is a problem, and engine running system voltage should always be higher than resting battery voltage, typically by at least 0.25V.
You can find a writeup I've posted on testing primary electrical components here, but make sure your DMM is properly calibrated and reading correctly first...
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #7 of 8 Old 07-23-2014, 04:23 AM
MadderThanMax
Wow! 29v that's Impressive... I guess you won't be posting on the HID light thread as yours will be jumping out they're sockets... Nice!
MadderThanMax is offline
post #8 of 8 Old 07-23-2014, 07:08 AM
BIGBADWOLF
If was 29 vdc at battery you would have to wear a gas mask. The hydrogen sulfide would either asphyxiate you or cause an explosion!
BIGBADWOLF is offline
