2003 WJ Rear Wiper - JeepForum.com
post #1 of 7 Old 06-10-2014, 02:54 AM Thread Starter
Phantom_Mark
2003 WJ
Wj 2003 WJ Rear Wiper
My rear wiper suddenly became lazy and has since all but ceased moving, common fault ? Easy to replace ?
Phantom_Mark is offline
post #2 of 7 Old 06-10-2014, 06:18 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Pretty common. Probably bad motor. Have to remove the lift gate interior trim panel to replace it. Be careful, I broke the trim panel where the plastic rivets go and had to buy a new one.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #3 of 7 Old 06-10-2014, 07:19 AM Thread Starter
Phantom_Mark
2003 WJ
By your description sounds tricky, regular tools ? anything special needed ?
ty
post #4 of 7 Old 06-10-2014, 07:31 AM
99WJ539918
I just did this. First remove the wiper arm and cap from the outside. That should reveal a nut you have to remove. The upper rear hatch trim pulls down easily. The bottom large section has three Philips head screws that need to be removed and then that trim can be removed. Both are held in by plastic push pins. Then the black water liner can be removed just by pulling on it. From there you can see the wiper motor on the inside which is held on by two nuts. It took me less than fifteen minutes to do mine. No special tools required.
Build Thread
99WJ539918 is offline
post #5 of 7 Old 06-10-2014, 08:49 AM Thread Starter
Phantom_Mark
2003 WJ
Great description thanks mate, will get a motor ordered thanks.
post #6 of 7 Old 06-10-2014, 09:10 AM
Jaspah
The motors are pretty easy to refurbish. They seize up because the weatherproofing on them wasn't meant to last 10+ years. You can easily check if you have a bad motor by briefly connecting it to a 12v source (car battery). There's threads on the forum on how to restore them for fairly cheap. Last I checked, refurbished motors were at least $50 or higher.
I ended up refurbishing mine and it works great now.
Jaspah is offline
post #7 of 7 Old 06-10-2014, 09:19 AM Thread Starter
Phantom_Mark
2003 WJ
I have a 12v source from the control switch don't I ?
The switch is working, it just went lazy, then slow, then not at all....I will look into the refurb tho thanks
