2003 Transfer case swap - JeepForum.com
post #1 of 5 Old 01-28-2014, 06:25 PM Thread Starter
lf0007
2003 WJ
I have an 03' V8 with the 247 t-case and it has started to fail. I found a used 242 with rear drive shaft from a 2000 V8. It looks like from the picture in the add that the front drive shaft on the 242 is not the U-Joint like my current 247. Is there anything else I would have to change other than the front yoke on the 242 so it would match up with my current front drive shaft?
I talked with the seller and he said the tag on the back of the 242 says 242WJ. I have read about a 242HD, and am just trying to make sure that the 242WJ will work for a swap.
lf0007 is offline
post #2 of 5 Old 01-28-2014, 07:48 PM
gcjeeping
gcjeeping's Avatar
Here ya go. Literally 100s of threads with what you wanna know.
http://www.jeepforum.com/forum/searc...rchid=25957345
_____________
gcjeeping is offline
post #3 of 5 Old 01-28-2014, 08:01 PM Thread Starter
lf0007
2003 WJ
I understand that, however I don't have time to go through 100's of different pages of info to find exactly what I am looking for. I want to snatch up this case if it will work before someone else does.
lf0007 is offline
post #4 of 5 Old 01-28-2014, 08:18 PM
Johnyre
It will work
As I roll down the trail,I hope my traction will not fail.But if I spin & begin to slide,please dear lord protect my ride
https://
http://fortcollinswheelers.com
Johnyre is offline
post #5 of 5 Old 01-29-2014, 06:11 AM Thread Starter
lf0007
2003 WJ
Originally Posted by Johnyre View Post
It will work
Thank you!
lf0007 is offline
