2003 Jeep Grand Cherokee WJ 4.7 HO several problems - JeepForum.com
post #1 of 8 Old 09-14-2010, 06:44 AM Thread Starter
marciad32
2003 WJ
Hello,
I have a few more problems that I wanted to turn to you guys for since you have helped me so much in the past.
My first question is simple on my 02 sensor I know I need it replaced and its $45.00 at Auto Zone for the Bosch 02 sensor is the wire long enough the part number is 13937 and my mom recently had to have her's replaced and the one they gave her the wire wouldn't reach so I want to make sure I don't run into the same problem.
Secondly, I had the whole heating system replaced the blower motor, blend doors and one other thing but I can't remember what it was called its located under the glove box well I had heat for 2 years and now no heat. I had a coolant flush yesterday and I had heat when I tested it but this morning no heat. Any suggestions.
The third thing and this is new so I have to still search on it but I figured I am send thing so I will add it to and it might not even be a question. I have to have the rear sway bar linkage kit replaced the driver rear side has a loose fitting is there anything special I need to know before having my fiance tackle this?
Thanks in advance.
marciad32 is offline
post #2 of 8 Old 09-14-2010, 07:59 AM
narnwv
narnwv's Avatar
O2 sensor--It's recommended to ONLY use Mopar parts from the dealer, especially if you have the 4.0 I6
heating system--no heat? more detail please. Does the fan spin? Does A/C work?
A basic socket set + a couple wrenches is all you need for the sway bar links.
~Aaron
narnwv is offline
post #3 of 8 Old 09-14-2010, 08:51 AM Thread Starter
marciad32
2003 WJ
I have a 4.7 HO
No heat - cold air blows out a/c never worked
post #4 of 8 Old 09-14-2010, 09:09 AM
WiCkeDuDe
WiCkeDuDe's Avatar
Spend a little more and get a mopar sensor. It will eliminate alot of headaches down the road.
I Have WJ Stuff for Sale
WiCkeDuDe is online now
post #5 of 8 Old 09-14-2010, 09:36 AM Thread Starter
marciad32
2003 WJ
What is the best way to find that part number? I need the left upstream before catalac convertor.
post #6 of 8 Old 09-14-2010, 11:09 AM
rm2001wj
rm2001wj's Avatar
You have two before the cat O2 sensors, one for each of the two minicats. The Mopar (Jeep 2001 -2003, 4.7L) numbers are:
Driver side (left bank) P/N = 56041942AA
Passenger side (right bank) P/N = 56041941AA
rm2001wj is offline
post #7 of 8 Old 09-14-2010, 06:58 PM
insjim
Check hoses going into heater core and see if they get hot " Heater core is possibly clogged" More than likely its your blend doors again....Check for codes on your computor on the heat display or drop glovebox and remove the blend door actuator and see if the BD shaft turns all the way around, If so $$$$$$
insjim is offline
post #8 of 8 Old 09-15-2010, 06:10 AM Thread Starter
marciad32
2003 WJ
I did try the test where you hold down the a/c and the recirc button and turn the dial once click and two numbers came up I believe they were 52 & 54 but I have it written down at home. I am so sick of not having any heat. Do the blend doors need to be recalibrated at a dealership?
2003 Jeep Grand Cherokee overheating arosier WJ Grand Cherokee Forum 36 08-12-2016 05:51 AM
2003 grand cherokee ac problems olebluetj WJ Grand Cherokee Forum 2 06-03-2010 11:29 AM
Electrical problems in 1999 Jeep Grand Cherokee BDASigEp WJ Grand Cherokee Forum 3 06-02-2010 10:14 PM
2003 Grand Cherokee BimmerMan WJ Grand Cherokee Forum 2 08-08-2003 05:07 AM
2003 Grand Cherokee Pricing bjmumy WJ Grand Cherokee Forum 5 07-29-2002 05:19 PM
