2003 Jeep Grand Cherokee overheating - Page 2 - JeepForum.com
post #16 of 37 Old 01-31-2011, 11:32 PM
garthfan0523
2003 WJ
My relay failed on me almost immediately after I bought my WJ back in December '07. After reading and reading and reading all the hundreds of posts in a dozen online forums about the stupid faulty relay and poorly-designed connector and hard-to-access location, I decided not to even fuss with it.
I wired the fan directly to the battery with a toggle in-cab. Problem solved. Very, very rarely ever need to activate the fan during the winter, seldom need to during the cooler spring and fall months unless I'm sitting in traffic. During the summer, I just check the temp gauge every now and then and activate the fan as needed. When driving, the ambient airflow through the grill is more than sufficient to cool the fluid in the radiator so I really only activate the fan when I'm sitting in traffic or driving slowly through city streets.
Been running it that way for two years, now, with absolutely no ill effects whatsoever to the fan, the wiring or the toggle. Just be sure to get appropriate-gauge wiring and toggle to handle the current loads.
garthfan0523 is offline
post #17 of 37 Old 02-01-2011, 08:54 AM
skitch3000
had this problem a couple months ago. fan would work when directly connected and thermostat seemed to be find. replaced the relay and haven't had any problems since
skitch3000 is offline
post #18 of 37 Old 02-01-2011, 09:04 AM
PhantomWJ
2003 WJ
Definately consider your temp relays but also ensure the you "bleed" you cooling system by eliminating any air that may be trapped....this is common...and can produce the symptoms you described.
PhantomWJ is online now
post #19 of 37 Old 02-02-2011, 09:52 AM
Big-Z
I and two guys from a shop concluded after looking in and out for the relay behind the headlight, and it does not exist. (its a 2004 electric cooling system GC) My fan wont come on at all. I cut the wires (two blue and one black) and I hooked it directly to the battery. the fan would not turn on. I hooked the blue to the + and the black to the - and the fan still did not come on. could that mean its a bad fan? did I hook the wires to the battery right?
thanks
Big-Z is offline
post #20 of 37 Old 02-03-2011, 08:20 AM
jgc86
The relay is located under the passenger headlight. The easiest way to get to it is to take a hole saw for a drill and cut throught the plastic under the headlight. I loooked it up online to make sure i didnt screw it up.
, hopefully that link works. Also here is the image attached just to make sure you get it.
jgc86 is offline
post #21 of 37 Old 08-18-2011, 06:25 PM
tastefulclient
2003 Jeep Grand Charokee
my car overheats when idling, i changed the thermosat, changed the senor and it's still overheating when im sitting at the light. please help. the fan does come on so im at my wits end..Please help.
tastefulclient is offline
post #22 of 37 Old 08-18-2011, 06:37 PM
4Tom
thanks
I was reading the 04 is different to 99-03
For 2004 only
Fan is two speed. So will have 3 wires.
There is two fan relays both located in main distribution unit beside battery.
99-03
Single speed fan 2 wires
Fan relay under headlight.
Hope this helps
WJ 2001 3.1TD
Tom
4Tom is offline
post #23 of 37 Old 08-19-2011, 08:56 AM
tastefulclient
what do you mean by "bleed"...like drain the radiator??
post #24 of 37 Old 09-24-2011, 08:15 PM
jeepsmsc
Wanted to share my experience. Have a 2003 Grand Cherokee Laredo 4.0L I6. 100k miles. Engine was overheating at idle when a/c was turned on. Took it to Jeep dealer. They diagnosed fan relay. They replaced fan relay for $225. I then left dealership and within minutes experienced same overheating problem when a/c turned on and vehicle at idle. Took it back to dealer. Dealer diagnoses fan / motor. Puts in new fan motor assembly for $320. Total out the door cost for both fan relay and motor is $545. Not sure if the fan relay was really the problem in the first place or if both the relay and motor were bad. Any thoughts? Did dealer charge a fair price? Also, this fan relay/motor overheat issue seems to be a recurrent problem for a lot of Jeep owners. Is there a class action on this fan relay / fan motor issue? Seems like a flawed Chrysler design.
jeepsmsc is offline
post #25 of 37 Old 09-24-2011, 08:17 PM
purplecty
2003 WJ
Imho u paid way 2 much... And it will happen again when warranty expires... Ask me how I kno...
Pearl Blue WJ Laredo 4.0-(202,xxx Miles) - COMPLETELY STOCK!!!
purplecty is offline
post #26 of 37 Old 09-24-2011, 08:22 PM
jeepsmsc
Thanks for the candid feedback on the overpay. I'm not a mechanic so doing the repair myself wasn't really an option. What's a fair market price for the repair? How frequently do the relays and fans go out on your model? This is the 2nd relay I've had put in. Last relay was at 55k.
jeepsmsc is offline
post #27 of 37 Old 09-24-2011, 09:13 PM
purplecty
2003 WJ
Dont take it the wrong way sorry my first few times I had my family mechanic replace with oem relays but only would warranty it for 1yr... Every 2 years theyde go out... Finally I found jeepforum ad learned instead of taking off bumper and grille u can take out passenger side headlight cut.a hole in bumper and there will b the fan relay. I opted to do myself since I knew it would happen again... Bought relay from autozone for like 55 with lifetime warranty and when they blow I get free replacement... neways dealers always charge 2 much find a independent shop u can trust... This is a job u can do easily. I am no mechanic by any means myself... This is probably at least. my 5th relay... Do some research on forum. Good luck 2 u... Its a design flaw
post #28 of 37 Old 09-22-2014, 08:38 PM
vluis
hey guys I think this is my first post, I want to say thank you to all of yall, every issue I've had with my Jeep Cherokee over the past few years I've managed to fix on my own with all yalls help. and I am now part of the cool kids check this out
vluis is offline
post #29 of 37 Old 03-04-2015, 06:32 AM
Bulldogger274
Question Location, location, location
I have a 2007 Grand Cherokee limited and have to change the cooling fan relay. Everything I see is for an older model. Is the fan relay in the same location under the headlight or did Jeep change it? Any help is appreciated.
Bulldogger274 is offline
post #30 of 37 Old 03-04-2015, 12:11 PM
Mattyjm
Mattyjm's Avatar
Originally Posted by Mattyjm View Post
I realize I'm not actually answering your original question, BUT.....
If you already have the five blade fan on your 4.0, that means someone (aftermarket) put it there. I was having constant issues with my e-fan and did a butt load of reading on here. I went with a seven blade fan from a 97 Grand Cherokee and a Torqflo clutch from AZ. I normally don't shop at AZ for my WJ, but after getting some good opinions from this forum, I bought that clutch instead of the one from Advance Auto.
I also have a 2000 WJ in Silverstone w/black cladding....We have the same Jeep and powertrain. I installed a 180 degree thermostat which is not recommended, but I did it anyway. After installing the 7 blade fan and clutch, my WJ now constantly runs and idles at a steady 180 degrees, which is what I like. Hope this helps you!
Fixing your overheating at idle problem with The Ickster:
First, add a clutch and a seven blade metal fan from an older 4.0L i6.
Then, you get rid of anything that's NOT a clutch and fan. (i.e.....constantly failing e-fan and relay)
Then, you enjoy driving your WJ at cooler than 210 degrees, and you never overheat at idle, while mall-crawling, while highway driving....or ANY other type of driving.
Thank you. This has been Fixing with The Ickster.
I looked over there <- one day and it said "Senior Member" and I was like...."Naaa
I'm only 43!"
Mattyjm is offline
How do I change the TPS on a 2003 jeep grand cherokee. dablk1 ZJ Grand Cherokee Forum 3 10-13-2009 01:54 PM
93 jeep grand cherokee overheating!! solano4224 ZJ Grand Cherokee Forum 8 09-16-2009 10:07 PM
2003 Jeep Grand Cherokee, need info please mess_85_1 ZJ Grand Cherokee Forum 6 03-04-2009 07:01 PM
2003 Jeep Grand Cherokee Exhuast SandMan817 ZJ Grand Cherokee Forum 6 01-31-2007 07:05 PM
2003 Jeep Grand Cherokee A/C Problem jnfann ZJ Grand Cherokee Forum 2 07-07-2006 07:42 PM
