2003 Grand Cherokee Stalls - JeepForum.com
post #1 of 2 Old 09-24-2013, 09:01 PM Thread Starter
Jed54
Had many things replaced on this thing... Just recently the can sensor. was told you should have no more problems.. today stall time. Cannot recall everything that has been replaced. In shop, 7 times.. Just looking for a response from anyone with the same issue in the past.... maybe there is something I've overlooked........ Thanks 4.0 litre ... 152K
Jed54 is offline
post #2 of 2 Old 09-24-2013, 09:49 PM
new2site
You stated "can sensor" ... did you mean crank p sensor or cam p sensor? guessing cam..
If cam ps was replaced it's most likely now your crank ps ....most common problem for stalling on these. Of course could be something else..
Do the "key dance" and see what if any codes come up on your odometer> turn key 3 times shy of cranking and then log code off odometer reading....if shows the word "done" you don't have any codes.
If you get code google it and post it back here...
new2site is offline
