2003 Grand Cherokee Limited blower stopped working - JeepForum.com
post #1 of 7 Old 09-14-2010, 08:04 PM Thread Starter
Acjeep11566
2003 FSJ Cherokee
Hello all. I have a 2003 Grand Cherokee Limited. 33,000 miles. Yesterday, the blower on the A/C and heater stopped working. It doesn't work on any settings (low/hi and in between). I also tried it without AC and on heater, defrost, etc
I've been reading that there is a connector that melts? Can someone tell me where this connector is located? Also, any ideas on what the issue/resolution may be?
Thanks much - great site
Acjeep11566 is offline
post #2 of 7 Old 09-14-2010, 08:42 PM
jtsjeep99
Its under the passenger side dash. Its the connector that plugs into the resistor and it overheats and melts. The dealer sells a repair kit for it or you can go to a jy and clip a new plug from one there. Pull the resistor and check the plugs. If its melted bad you may not be able to disconnect it without cutting it. Make sure you leave as much wire as possible so you have some extra to work with when installing the new one.
JTsJeep99
jtsjeep99 is offline
post #3 of 7 Old 09-15-2010, 12:32 AM
Falkon
Falkon is offline
post #4 of 7 Old 09-15-2010, 12:13 PM Thread Starter
Acjeep11566
2003 FSJ Cherokee
Thats the your help. Im kinda new to this, so sorry if Im asking "simple" questions. You mention its under the dash board - is that behind the Glove box or actually under the dash board. I replaced a tweeter recently, and removed part of the dash, just not exactly sure how to remove the entire dash (if necessary). Also, if you have the Mopar Part #, that will help.
Thank again!!
post #5 of 7 Old 09-15-2010, 01:03 PM
GhostKnife
crawl into the passenger floor board and look up under the dash, you will see a round object, and 3 wires taped up comming out from it. theres a clip that needs to be pulled out where those 3 wires go. Pull it out if you can and check to see if it is melted. if so, cut and replace. if not, keep checking
13 Ram Cummins, PPEI Tuned and Full Carli/Thuren. JK Arctic Edition 2dr Winter Chill
GhostKnife is offline
post #6 of 7 Old 08-19-2014, 01:35 PM
meepjeep
Follow up
meepjeep is offline
post #7 of 7 Old 08-19-2014, 02:02 PM
rdkendrick
2003 WJ
To elaborate on JTSJEEP99, the connector melts, then warps, causing the connectors to break contact with each other.
X2 on crawling underneath, unplugging fan plug, and buying a new wiring kit.
I just bought the wiring kit, instead of the new resistor kit, it was cheaper, and my plug has not melted anymore. I forget what the p/n is, but I think it's in www.wjjeeps.com.
Sent from my iPad using Electrons
rdkendrick is offline
2003 Grand Cherokee Overland matt21484 WJ Grand Cherokee Forum 21 06-25-2012 06:53 PM
Grand Cherokee blower motor stopped today DickeyeFab WJ Grand Cherokee Forum 17 07-21-2010 04:59 PM
2003 grand cherokee ac problems olebluetj WJ Grand Cherokee Forum 2 06-03-2010 11:29 AM
2003 Grand Cherokee Overland... jonsjeep WJ Grand Cherokee Forum 15 06-08-2004 11:59 AM
2003 Grand Cherokee BimmerMan WJ Grand Cherokee Forum 2 08-08-2003 05:07 AM
