2003 4.7 swap into a 2000 with 4.7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > 2003 4.7 swap into a 2000 with 4.7
8500 Lb. Rugged Ridge Winch $239.95 Delivered after $20 MaXJ guys, clock your transfer case!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 02-16-2012, 01:00 PM   #1
adub_03
I'm just wondering if a 03 will work in a 00 without serious modifications?
adub_03 is offline   Reply With Quote
Unread 02-17-2012, 04:24 AM   #2
Bphase
Yes. Yes it will. So will the high output. Just make sure the tone rings are the same tooth count on both motors.
Bphase is offline   Reply With Quote
Unread 02-17-2012, 01:32 PM   #3
adub_03
Thanks for the input!
Unread 02-20-2012, 02:46 AM   #4
GRAND_WJ
So as long as these two things are the same your saying that it will work...no comp mods, elec mods, ECT...
'01 WJ Limited, 4.7v8 QT2, VSI LPG, airraid throttle body spacer, airflow snorkle, 8" lift, knuckle over tie rod, LA front/rear, bilsteins, 265/75r16 geolanders, ARB frontbar, 12000 pound winch, full recovery bag, on board air, XXX 220 spot lights, rola roof rack, soon to be locked, re-geared, 35's, 17x9 MT sidebiters and Notch custom flares ...
GRAND_WJ is offline   Reply With Quote
Unread 02-20-2012, 09:08 AM   #5
yrkoverland
IIRC the 2003 and 2004 motors were all 32t rings, and 1999-2002 were 16T. ALL HO motors are 16T.
So if the tone rings are different you will have to swap them. One on pass cam, and one on the crank. Kind of a PITA.
I swapped a HO motor into my 2000 and just reused the harness from my 2000, and got a custom tune from hemifever.
2000 WJ- 4.7L HO swap, 247, 4" tera-flex lift, 32's, KOR Rock Rails, IRO Skid, etc...
2007 VW Touareg V10 TDI gobs of torque!
2004 Audi A8L Luxobarge
2008 Z06 cammed and slammed
yrkoverland is offline   Reply With Quote
Unread 02-20-2012, 09:36 AM   #6
Bphase
I put a 2004 ho into my 1999 with a non high output. I didn't change anything computing wise but had to change the oil pressure sending unit . I had to use the one off my old motor and had to use my old throttle body too.
