2003 4.0 4x4 TC fluid - JeepForum.com
post #1 of 7 Old 07-06-2013, 03:44 PM Thread Starter
elcorvino
2003 WJ
Does the TC take the same ATF-4 as the tranny? Not easy to use search on a iPhone.
elcorvino is offline
post #2 of 7 Old 07-06-2013, 03:56 PM
rcwj04
The 242 tc which you have takes ATF-4 the 247 which is behind the 4.7's requires a special fluid
You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
Just a 19 year old kid with a Jeep, and broke because of it, and loving every moment.
2004 WJ Laredo 4.0 116k
2" BDS coils & Bilstein 5100's | Addco rear swaybar with energy bushings |
K&N FIPK | glasspack | plasti-dipped badges | 17" moabs | HID's, 245/65/17 Cooper Discover AT3 | Rola rack | Fawkes stand alone shackle tabs | Bed lined interior (what a pain that was)
rcwj04 is offline
post #3 of 7 Old 07-06-2013, 04:03 PM
MuddyWJ
You can get both engines with both TCs fyi. RC is right though 242(selec-trac) gets same as trans and 247(quadra-drive and quadra-trac 2) gets dealer 247 fluid or mobil424.
MuddyWJ is offline
post #4 of 7 Old 07-06-2013, 04:17 PM
ADragg
2003 WJ
Yep, if anyone is unsure if they have the 242 T-case, just look at the plastic bezel around your shifters and if it says Selec-Trac, then you can use ATF+4. If it says anything else, you should ONLY use the special "Mopar 245/247/249" fluid (that's actually what it's called). Part #05016796AC. You can get it from the dealer easily.
3.5" lifted '03 Limited Quadra Drive WJ - OME HD coils, Bilstein 5100 shocks, JKS track bar, IRO extended links, OME 10mm spacers, Moog SS, JK Moab wheels w/ 265/70/17 (32") Goodyear Duratracs.
ADragg is offline
post #5 of 7 Old 07-06-2013, 04:30 PM
rcwj04
I know you can get the 242 with the v8 and vise versa but typically speaking the v8 gets the 247 more times than not
rcwj04 is offline
post #6 of 7 Old 07-06-2013, 04:44 PM Thread Starter
elcorvino
2003 WJ
No seals to replace? Just unbolt, drain, refill?
post #7 of 7 Old 07-06-2013, 04:52 PM
rcwj04
Don't need to drop the case. If you look at it from the back you will see the plate that says what model it is and yada yada. Slightly above that or near it will be a metric 10 Allen bolt. That is the fill hole, three inches below it and to the left is the drain hole. Make sure to take the fill bolt off first. You will need a pump of some kind to get the new fluid in there. Keep putting in fluid until it starts to come out of the fill hole, which is around 2 quarts. No need to buy the expensive ATF-4 either. It is all the same, so the store brand will do just fine
rcwj04 is offline
