2002 WJ worn transfer case...HELP - Page 3 - JeepForum.com
post #31 of 42 Old 09-20-2013, 06:57 PM
rdkendrick
2003 WJ
Originally Posted by 914pete View Post
Another issue, when I shift into reverse and start backing up, the back up lights don't come on. I have to move the shifter between reverse and neutral and hold it there in order to keep the back up lights on. The jeep dealer tells me I need a new neutral safety switch. Does that seem right?
Just checked and I still have the pictures on my iPad. The 42RE has neutral/safety switch, but the (5)45RFE has a Transmission Range Sensor. There's also a Brake-Transmission Shift Interlock adjustment you can do.
Sent from my iPad using my fingers
rdkendrick is offline
post #32 of 42 Old 09-22-2013, 07:14 PM Thread Starter
914pete
Good info. It was the Neutral Safety Switch. Simple removal/install. Took 5 minutes. 1" deep socket to remove/install. Back up lights work again $28 (Mopar). Dealer wanted $150 to replace it.
914pete is offline
post #33 of 42 Old 09-22-2013, 07:25 PM Thread Starter
914pete
So, I removed the front DS. Very easy. Took 10 minutes. Drove it at highway speeds without the DS and no more noise/vibrations. While removing it, I think I found the problem with the loud grinding knocking going on when the 4WD is engaged. The front DS rear CV joint is shot. The boot was disintegrated, bearings exposed, rusty dry and gritty in there. I could barely move the spline inside the CV joint.
My front drive shaft has a universal joint at the differential and a CV joint at the TC. I can't seem to find a diagram of this set up on the web? I'm hoping I can just replace the CV joint and the spline as a unit rather then buy a whole new DS which I can't seem to find mine anyway. Any thoughts?
914pete is offline
post #34 of 42 Old 09-22-2013, 09:08 PM
WJ297
I would personally look into the IRO conversion kit to a double cardan drive shaft. This one has two u joints at the t case and one at the diff. You would only need one yoke (for the t case). Although it is a little pricy but I did the conversion and I have no complaints, no vibes and it seems to be a lot stronger. I had the cv at both ends.
WJ297 is offline
post #35 of 42 Old 09-22-2013, 10:05 PM
brouwmat
Agreed .. Either that one or look at a ZJ shaft. I bought mine and rebuilt it for about half the cost of a new one. Plenty of threads on this on the site.
Mine did the same thing and from your description it was the same shaft.
brouwmat is offline
post #36 of 42 Old 09-23-2013, 07:12 AM Thread Starter
914pete
Thanks for the advice however, I need to do this as inexpensively as possible. My jeep is totally stock, no lift. I got 210,000 miles out of the first DS. Is it odd that I can't find my DS on Google anywhere? I've seen plenty with the CV's at both ends.
914pete is offline
post #37 of 42 Old 09-23-2013, 07:24 AM
skain8
skain8's Avatar
The stock rzeppa style shaft is perfectly fine for your application, and is a lot smoother during operation than the coventional double cardan. You should be able to find replacement/rebuild parts online. Or, visit your local driveline shop.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #38 of 42 Old 09-23-2013, 07:41 AM
mikeyc1821
i had the same drive shaft as you, Pepboys can get a rebuild kit for the rzeppa joint for about 125 bucks... I was lifting my jeep 4 inchs, so i went and got a double cardon DS from an 04 4.7 wj and the yoke for the Xfer case..
If you want you can buy my old driveshaft... Its not wiped right out and worked fine untill i lifted my jeep... I would however rebuild it anyways...
mikeyc1821 is offline
post #39 of 42 Old 09-23-2013, 07:47 AM Thread Starter
914pete
Thanks. My DS is good just need the CV. I will probably replace the universal joint too while I have it out.
914pete is offline
post #40 of 42 Old 10-11-2013, 06:35 AM Thread Starter
914pete
Welp, all I needed was the rear CV joint on the front drive shaft. Fricken Jeep dealer charged me $120 to tell me the transfer case and front drive shaft needed replacing to the tune of $3700 for parts only....Probably another $1000 for labor. Bastards! Does anyone actually FIX anything anymore? I bought a CV joint on Ebay from Detroit Axle for $57.00. Easy fix. I couldn't see anything wrong at all with the front universal joint so I left it. 4WD works great again, no noise at all. Thanks for the help fellas!
914pete is offline
post #41 of 42 Old 08-06-2014, 05:47 PM
ballyhoo2014
Question about original post
The OP said he drove his 2002 WJ for 1.5 years in 2wd and it was fine in spite of the TC problem.
Is the same thing possible in the 2004?
Thanks in advance, folks.
ballyhoo2014 is offline
post #42 of 42 Old 08-06-2014, 07:29 PM
brouwmat
He didn't have a TC issue. It was the rear CV on the DS. Do as he did and remove it before you do anything else. If that resolves any vibration issues you have then it is likely that your issue is just the DS.
Sent from AutoGuide.com App
brouwmat is offline
