2002 WJ OVERLAND heated seats don't work - JeepForum.com
post #1 of 6 Old 01-20-2013, 11:34 AM Thread Starter
jean-karim
Hi all,
Both front seats on my 2002 WJ Overland don't work, I mean no heat at all from any part of the seats. I have checked all the fuses and they are OK , both switches light up so I was thinking about that C2 breaker but does it control only the heat but also the power motrs of the seats? My motors all work. Then could it be both modules? all the pads in the seats???
Thank you for any sugggestion!
jean-karim is offline
post #2 of 6 Old 01-20-2013, 02:54 PM
Rekots
2003 WJ
Thumbs up
... I have the same issue with mine J-K, so I guess I will be watching this thread ! Mine is an 03 thou.
Rekots is offline
post #3 of 6 Old 01-20-2013, 03:04 PM
Son-of-Beast
2010 JK Wrangler
Normal issue is a break/short in the bottom cushion under a cross bar in the seat cushion. Several good write-ups for troubleshooting from a quick search here - I will be doing this soon myself.
Dorman makes a plug-and-play replacement kit for the bottom element or both elements, and features a better design for the bottom cushion, seems like most of the DIY fixes only last for a season or two though.
2010 JKU Rubi, 6-spd, AEV Frt, Warn 9.5, SRC Side Armor, Rancho Rr Carrier, 730RER, BFG M-T KM's
Son-of-Beast is offline
post #4 of 6 Old 01-20-2013, 03:21 PM
jserna
1987 YJ Wrangler
Check to see if yours was recalled. My 04 had a recall on the heated seats. Mine were not working either, now my arse gets toasty warm.
jserna is offline
post #5 of 6 Old 01-20-2013, 03:55 PM Thread Starter
jean-karim
Already called and guess what , not a recall one.. Is the bottom pad hooked with the back one so then nothing works? Is the C2 Breaker only for the heated elements or also the power motors?
post #6 of 6 Old 01-20-2013, 04:18 PM
Son-of-Beast
2010 JK Wrangler
Not sure about the C2 breaker but yes, if the bottom is shorted the back pad can't heat up.
