2002 WJ 4.0 ltr rumbling and shaking! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > 2002 WJ 4.0 ltr rumbling and shaking!
Rampage Bowless Soft Top Oconee offroadAlloy USA Still AvailableAdvance Adapters SYE Kits
Unread Today, 04:39 PM   #1
just jeepin
Wj 2002 WJ 4.0 ltr rumbling and shaking!
Hey all, have a problem I know some here may have had to tackle and hope to get advice. Several weeks ago I ran my gas too low and sucked up some crud apparently from my tank. Lots of hesitation for a day or two before it finally threw a code saying a misfire on #4 cylinder. Changed all 6 plugs and reset code and ran ok for about a day. At about 1500 to 1600 rpm I get a severe shake from the motor and the motor seems to be hesitating a lot.
In the past two weeks I have replaced my plugs, changed out the #4 fuel injector, run 4 or 5 cans of sea foam through the gas tank and through the engine thru a vacuum line, and had the dealer hook it up for their diagnostics thinking they would find any leaks before I could. All leads come back to it throwing the code again for #4 cylinder misfire.
Recommendations? What can I do to get my old engine back? Prior to screwing up and driving my tank too low I had a 4.0 with all the pull and performance I wanted. Now at 40-50 mph and engine up to temp it feels like I'm riding the bull at Gilly's for 8 seconds. Someone mentioned sensors at the cam shaft or crank shaft. Could they be affected by gas tank sludge? Help!!!
just jeepin is offline   Reply With Quote Quick reply to this message
Unread Today, 09:55 PM   #2
strongt
2003 WJ
Fuel Filter ?
2003 WJ 4.0L 188,000 miles
strongt is online now   Reply With Quote Quick reply to this message
